'LGT' Construction Diary
I'm surprised you have gone for an 8" and a 5"... I think my choice might have been using maybe an 18cm or a 23cm C-Quenze from about 80Hz-1.5KHz instead of splitting it up. Did you not feel 2x 18cm drivers would have done the job okay for extending down to 80Hz?
Still it seems you have ordered now. Very nice design I have to say!
Idefixes said:
Hi ShinOBIWAN,
All pictures on Perceive v2.0 topics are down. Is there any place where we can take à look at all the pictures you have posted?
Marc
Hi Marc
I've bit the bullet and am paying for image hosting now. This will allow to host all images and not have to keep deleting older ones to make way for the new, you should find that the majority of the images in the Perceive 2 thread are working again. The early ones in that thread I can't fix because they where hosted on a different server but the rest should be OK from about page 30 onwards.
They're pretty spread out though because the thread is quite large. Here's a couple if you can't be bothered to hunt through:
Hey Simon
A 5" cone covering that range perhaps doesn't have the right weight so you lose some of the slam and impact. Likewise using an 8" crossed to a good ribbon like the RAAL might not offer the same integration that a 5" would with its much light cone mass and higher acceleration factor. I've aimed for effectively targeting each range with a compromise between cone mass and radiating area for greater dynamics, lower distortion and greater headroom. Moving the XO point upto 200hz for the little C-Quenze mid will quite significantly reduce IMD and THD and the pair of larger 8" will be happy running down to 40-50hz. I also wouldn't like to use a side firing sub upto 80hz vs. a pair of 8" rolling off naturally and the sub covering the very bottom.
I've tried to design a full range speaker that still has the virtues of a floorstander such as weigh and solidity through the bass region and also a standmount with its midrange and imaging strengths as well as a subwoofer. I had to weigh this up against the usual problem of size as well as try to best optimise for lower distortion. Whether that will be the case when they're finished is another matter but for now its making sense.
I've been trying to get my head around TS theory and calculations so as to tailor an 8" Flex unit driver specifically for the 40-200hz range. Ideally with a modelled F3 of around 50hz in a 20ltr sealed enclosure. Those are the constraint I have to work with.
I don't want to approach Per with my order until I have something that is actually feasible otherwise I'll just end up looking like an idiot 😉
What I've come up with so far is:
Qts: 3.29
Qes: 0.4
Qms: 1.85
Fs: 25hz
VAS: 40ltrs
Mms: 70g
With this I get the box and driver resonances below 50hz and the impedance phase is smooth from 50hz to 200hz. Its also -3dB at 50hz in a sealed 20ltr box with an over system Q of 0.6.
The other approach was to forget the keeping the box resonance out of the passband and go with something geared for a little more effeciency and lighter mms:
Qts: 3.81
Qms: 1.6
Qes: 0.5
Fs: 33hz
VAS: 40ltrs
Mms: 40g
Any thoughts?
I guess I should really just pick Per brain about this but at least wanted to have something valid to work from.
You've either got your Qes, Qms and Qts all mixed up or there's something wrong. Box Q can never be lower than Qts.
I would aim for Qts around 0.35-0.45. Qms and Qes will have to be juggled according to motor and suspension requirements/constraints. It might also be worth specifying a target BL range, I feel a highish (>8) BL gives more slam and control to the sound which is what I think you're after.
As you know your box volume you can then work back to what Vas would give you the desired box Q.
The trouble is a lot of parameters interact. For instance Vas will be influenced by Fs.
Sorry Rich I got the decimal place in the wrong spot, those should have read:
Qts: 0.329
Qes: 0.4
Qms: 1.85
Fs: 25hz
VAS: 40ltrs
Mms: 70g
Qts: 0.381
Qms: 1.6
Qes: 0.5
Fs: 33hz
VAS: 40ltrs
Mms: 40g
Yeah its a tough job to make changes, is there any sort of auto calculate utility that will do all the lot instead of having to work through the formula's?
tinitus said:
Order the softest surround he has
What are efficiency of all drivers - what are your goal fore overall sensitivity
Its looking very likely that I'll be going active again as things have gotten more complicated since the initial idea I had for use with passive. So sensitivity isn't really that much of an issue anymore but the treble is around 95 and the mids around 94. Its going to be impossible to get an 8" to extend to an F3 of 50hz in a 20ltr sealed enclosure whilst simultaneously have a sensitivity of 90dB+. So what I'm going to have to do is take a knock and look at around 85dB+. The largest flexunit motor for the 8" is an 200mm magnet on a 230mm frame which should have a formidible field strength, if I make it overhung and go with a 4" voice coil then that will help things once the driver Fs and VAS start to drop.
Can anyone tell me what effects changing a 3" coil to 4" one has? Is it just Qes, Qts, BL, mms, re and fs or are there more?
This is way over my head. I just fail to see the all the relationships between the parameters. Really need a bit of guidance here.
Well, I cant help but thinking that 4 x 10" (Beyma 10BR60 ?)pr side would be the right thing to deal with 40-300 hz
and the result would be a much simpler construction
and they would be able to take some EQ
and without the side woofers you would have less phase problems to deal with
and end up with much better efficiency
edit... or 4 x 8" AT with good Xmax and low Fs, if thats preferable
Originally posted by tinitus Well, I cant help but thinking that 4 x 10" pr side would be the right thing to deal with 40-300 hz
Are you saying ditch the subs and just go with a speaker that does 40hz+?
BTW The only drivers left to order are the 8" so at this point I've made my bed and will have to lay in it. 🙂
10's that would elegantly run upto 300hz and storm down to 15hz after EQ don't really exist or at least I haven't found any yet. Running 20hz at fairly high SPL's on a 10" would knock the s**t out of IMD.
Phase problems? If you consider the subs blending in around 40hz then that frequency has a wavelength of about 8.5m. All 4x side firing 10's would effectively couple as the 1/2 wavelength rule applies, the dispersion will be omni at those frequencies so the same coupling will apply between the 8's and 10's, there's also the delays to refine things further. If anything, more room modes will be excited and more evenly since your working with 4 woofers and 4 subs working in different planes and they still remain consistent in distance from the listening spot.
Deep bass is always inefficient, you either have to build a horn the size of a garage or you make up with numbers, displacement and amplifier power if your wanting things more manageable. Thats pretty much why I decided on the 4 side firing XLS10's, they only have a very limited but demanding range to work in. The rest of the range can be optimised with the use of more suited drivers.
It all looks pretty ambitious at the moment and there's a hell of a lot of hearsay on my part - it could turn out to be the biggest POS ever to grace this good forum. But my gut feeling says that this is the best way to go about what I'm really after, the others designs were me compromising, this is the one I really wanted to build from the start. Much will depend on the XO and I've been well prepared with all my active experiments on the Perceives.
Thanks for the input.
I think I've nailed the internal partitions:
Blue = mid enclosure (7ltrs)
Green = bass enclosure (20ltrs)
Red = sub enclosure (20ltrs)
All volumes are after bracing.
The problem is maintaining the relative cabinet dimensions/driver positioning and distributing the relevant volumes between the drivers. Its a bit convoluted but gets the job done. Really could do with about 25-30ltrs for the bass driver to work in, might have to widen and make the cabinets slightly taller to do this. The XLS10 is more than happy with 20ltrs and yields a critically damped alignment with this.
ShinOBIWAN said:
Hi Marc
Very very beautiful realization
Angelilo
