let peak meter show RMS value !?
i am not sure if that is possible analogue but i like to let my analogue peak meter RTW 1206 show true RME value.
is there a schematic available or is this possible to do ??
i knoe that attack time is different to peak..
thanks
Junoman23
You will have to precondition the signal with a true RMS circiut,
(square the signal value, analogue multiplier, then average it,
the averaging time constant is an issue here.)
Your peak meter will then show the RMS value.
Presumably your meter is the peak hold type, so it will be
showing the peak RMS values of the time constant you have
chosen, unless you have a long time constant, which will just
indicate a relatively steady 10 to 30 dB below peak level.
Perhaps you need VU indication, which is essentially a
RMS indicator with time values suited to analogue tape.
🙂 sreten.
Why?
The only reason for using an RMS-reading meter is for measuring power. If the waveform is distorted, yet you need to know the heating effect (power) you truly do need an RMS-reading meter. If you want to measure audio power, then you're only interested in undistorted waveforms, in which case, you just apply the 1 over sqrt 2 scaling factor to your peak reading.
A VU meter is average responding, calibrated RMS of sine wave. Lots of claims are made for VU meters, but the only claim that stands up is that they are cheap.
A peak hold meter will give perfectly sensible results using the 1 over root 2 scaling factor provided that an undistorted sine wave is used.
Turning to RMS, power developed by music is irrelevant. What is actually important is the voltage developed across the load. Thus, an amplifier for a tweeter with the same sensitivity as the woofer must develop the same voltage, even though the power dissipated in the tweeter is minimal. The whole point of a peak hold meter is to warn of imminent clipping of devices that don't take kindly to clipping - like AM transmitters and A-Ds, so peak voltage is the correct measure, and RMS would be wrong.
I have already explained that RMS is not a relevant measure for music (unless you are considering the design of heatsinks or power supplies for class B amplifiers).
Peak is the proper engineering measure for music and any equipment passing it.
Basically couldn't agree more.
But as said, peak hold scaled cannot be used to measure
RMS values of music.
Stating that "RMS is not relevant for music" is not remotely
the same as "this method cannot measure music RMS values".
What is missing is what " True RMS " is wanted to
measure, its unlikely this requirement is sensible.
🙂 sreten.
I should have thought that a cutting lathe is very definitely an application where peak is important. You have amplifiers driving the cutting head that must not be clipped, a fragile cutting head, and you must ensure that the peak level you cut can be tracked cleanly by a cartridge.
RMS and loudness are not directly related.
i know i know,
i read my peaks on the cutting current meter, but this says nothing about the loudness,
it is very important if you have more then one track per side
to see the diffenrence in loudness, usually all music is levelled up to 0dBfs digitally. so you peak will show very similar levels but says nothing about volume.
no discussion needed i know what i need and just bought an dorrough loudness meter.
best regards
junoman23
