I tried searching but for some reason i cant on my phone
Anyways. How do you exactly wire the mini amp to run on a 12v battery pack
Do you have a DC coax power connector to connect the battery and Lepai? If so, connect the center pin to + and the sleeve to -.
Thanks for the quick reply. Just received it today and its just the mini amp and plug. So i pretty much plug it in and splice it? And run it straight to the negative and positive of the battery? I just dont wanna mess up n fry something. Thanks for the quick response
Thank u guys. With ur help i got it now
Im building a lil boombox to run off of 12v battery as well as wall socket plug, charging the battery at the same timetoo. Now im trying to figure that out searching threads here
Another question...how would go about running it from battery and charger at the same time. Would i need a relay switch?
