i was recently given a Lenoxx HT-4 powered 5.1 subwoofer
its got a dolby/DTS decoder in it + normal analauge inputs and it has 5 sattelite amps + subwoofer amp.
i only have the actual subwoofer box with plateamp and the only controls on it are Power, Reset and Input select... the probem is to change the volume and variouse other features it has a DB-9 "serial" style connector on it which plugs into a controller of sum sort
has anyone got the pinouts to that socket??
because right now i cant turn it up or down
thnx haydn
thnx haydn
