Lenco Heaven Nigel's Speed Controller PCB
**Sold **Lenco Heaven Nigel's Speed Controller PCB
For sale is a built and working Nigel Speed Controller PCB, set up for 33/45/78 speeds. See the second picture which was taken prior to disassembly.
I built this a few years ago. It worked well and ran cool. I am changing to a Pyramid (DiyAudio) PS so will re-use the case and displays.
Included is everything in the first picture. The only thing non standard is the voltage control pot which is 10k and not 20k. As set up it gives around 160 to 250 v adjustment.
The heat sink was bolted to the case. It is the recommended size or greater and runs cool. Threaded holes and bolts included.
https://www.lencoheaven.net/forum/index.php?topic=16910.0
Requires a 2x25v toroid, for the amp and 2 x 15v toroid for stepup. See third picture. My toroids were Overkill and will be reused.
You will need new insulators as the keratherm I used ripped when I disassembled.
I can provide the build instructions in pdf. Plenty of info and build help on LH site.
Spare XR2206 chip included. Nearly all components were bought from Mouser/RS supplies. Pots from ebay.
Asking for AUD$100 plus postage from Perth, Australia. That is around $60 US. ONO
Gigigirl,
I have PM'd you. The Singaporean guy has pulled out. He didn't want the heat sink and I didn't want to drop the price. Let me know quick please as there are a couple more in line, both in Aus. too.
Regards,
kffern
