Legato power and jumpers
You could power both balances channels with one supply and the Bal->se with the other supply, or power the bal->se from one of the two channels.
Using the jumpers is fairly straight forward, just follow the traces.
Ok, thanks for the answer Brian. I don't want to stress small Talema toroids to much. They are rated 500mA max. but they got quite warm with my current setup using two placid BP-s for powering Legato 1 with buffer but no jumpers meaning bal/se is left un-powered.
What would be better the compromise in this case? Also if I decide to go for powering the bal->se from one of the two channels, what would be approx. consumption for bal/se part alone and what for one full Legato channel?
