Left speaker channel is dead, Topping MX3
Hello everyone! I thought you might be able to help me to do a DIY repair 🙂
So, i have a Topping Mx3 that has been lovely in my garden house. Didn't think of bring it indoor during winter. The problem is most certain caused by condensation or too cold temperatures. Have opened the amp and had it indoor for more than a month. Cleaned the circuit board with Isopropanol, but the problem persists
Where do I start to troubleshoot the board? All tips a welcome!
Symptom when I connect the speakers:
  • Left + and Left -. Dead silent.
  • Right + and Right -, Sound
  • Left + Right -, Sound.
  • Right + Left -, Sound
When I meassure:
Left + and -, around 10 k ohm.
Right + and -, around 10 k ohm.
Just lay it on a wood desk etc. and gently poke around with an insulated tool, maybe a pencil eraser to start.
If you find an area that is sensitive, use a smaller, harder tool to localize it further.
It's much more likely to be a bad solder joint than a bad component.
Also try reseating any connectors.
Seems like I have forgot to clean and inspect the front circuit board to the volume knob and LCD screen. There are a lot of suspicious residues. Will be tomorrows adventure! The big soldering points to the right are attaching the volume knob.
