Led's on power supply output?
There are two independent secondaries, each with a FWB (full wave bridge) rectifier,
each circuit generating one DC voltage. Then the two output voltages are connected
in series, with the common connection "grounded" to form a bipolar supply.
If the two secondaries were connected in series to form a center tap, then only four diodes
would be needed to form a bipolar supply.
Bridge Rectifier Circuit - Design Details & Tips >> Electronics Notes
The two circuit types require different secondary voltages, to have the same output voltages.
If you have a single CT secondary, the decision is made. If you have two secondaries,
you could go either way if you have a choice of secondary voltages. For higher currents
I'd go with two secondaries and two FWB rectifiers. The two supply outputs would be connected
together at one point which is taken as the common. That one is the schematic that you have.
There can be some "upmarket reasons " although just one full-wave rectifier would do but this question was put on a professional electronics website forum (USA ) and one of the older "heavy hitters " wasn't so nice about it saying-
Yes, you could also use separate bridge rectifiers on each of the secondaries, and then wire the outputs into a dual rail, +15 and -15V output arrangement. There are some "audiophool" circuits that use that topology. They think that having MORE components somehow makes the circuit "better". Of course there is no merit in that fantasy, but audiophools are very stubborn and dislike facts.
The above aren't my words but a pretty sarcastic sounding guy with an obvious chip on his shoulder.
Have to decide first how much output voltage, and how much DC load current, is required.
Seems the amp uses +/- 12VDC supplies. The 4A fuses would imply around an amp or so.
If you do want 12V supplies, the secondaries should be more like 10VAC each, but it depends.
The 15VAC secondaries would definitely be too high for an unregulated 12V supply like this.
Since this is same as the diyAudio power supply board, you could use that board.
Universal Power Supply – diyAudio Store
@ the old time heavy hitters of the other website. If we were only concerned with what would do the job there would no need for this forum! We would all simply buy the first hi-fi we saw as they all do the same job! Hell lots of people would argue there is simply no need for so many large Capacitors in this type of circuit but I and many other people bought them anyway.
The "fool" circuits will usually have less hum and noise, since there's no center tap
with charging pulses going through it.
As a tech, I see no real reason to design such a complicated supply.
Besides, either way, the grounds come to a common point.
And I've never come across a properly designed "common ground" PS that had hum or noise.
But, some like to nitpick themselves to death over the complexity and alleged benefits of such things.
I was ready to buy 9-0-9 transformer but the circuit threw me off!
Would two of the DIY audio boards basically give the same as what I have got?
I think there's only one diyAudio power supply board. It has two independent FWB supplies on it, like your schematic.
Not sure how you could use 15VAC secondaries for the amplifier that needs 12VDC supplies.
Adding regulators to the supply outputs could drop the voltages, but that would dissipate some power.
Depends on the current draw of the amplifier what you could do.
I got confused by the link, I think it is 9v secondaries I need.
