LED peak level indicator
So I'm a big fan of blinking LED's and so on, so I was thinking it would be pretty cool to have a red and green (right and left) LED inside my preamp that would illuminate when a desired level was reached on the input. I searched around the web and couldn't really find what I was looking for so I thought I would come here for help. The closest I've found is this:
But it is stated to work more on speaker outputs (>1000mV), and what I want is something for line levels.
So, can someone help me with a simple simple circuit that could do what I want, preferably run on 12-15v and use 2n2222 or 2n5089 transistors? I dont want to use any IC's because I dont have them and would rather build this out of what I might have in my parts bin.
Thanks!
Problems... thinking aloud here... and this is not an ideal circuit tbh
The circuit will only illuminate the LED when Vin exceeds the diode volt drop + the base emitter voltage of transistor. So that's nearly 1.5 volts to begin... no good.
You could add simple biasing to the transistor using either two resistors (if you calculate exactly) or a pot. That would allow the base to be brought to around 0.6volts (just below turn on voltage) and make the circuit much more sensitive.
Use a germanium diode (0.15 against 0.7v)
Omit the series diode altogether and add it B to E to protect against negative inputs.
Use a FET which would allow much higher impedances (less loading on audio circuit).
Or better still... use any opamp such as a 741
I found this one after a little more looking. Looks like the comparator circuits ive seen.
WOuld this work with other opamps equally as well? I was quite a few 2277p in my bin.
