Leaving Long Leads on Film Capacitors
Hi All!
I have a question-- I'm recapping an integrated tube amplifier and I don't have much room when swapping in new coupling capacitors. It looks like I have two choices: (1) seek out small film caps that don't cause me issue; or (2) allow longer lead runs from the caps to their solder points. This is a point-to-point solder framework.
Option 1 leaves me with less than desirable (for me) choices.
Option 2 raises the question of whether it's a bad think to have 2.5" or more leads running from the cap to the point of attachment. I would use tubing or heat shrink to insulate the leads.
Thank you in advance.
