We compared Eikona (in Hawking) vrs A11ms in Seastack vrs A10.3eN in Pensil.
A11ms was the overall winner, but the A10.3eN imaged better.
I am looking to put A11ms in Hawking now.
dave
dave
This is very impressive indeed But involves also 4 identical woofers ... however i have seen that done before also in the very top models from Krell and Magico ... same concept i thinkBecause the drivers are heavy. In my push-push SDX10 woofers, one could use 2 fingers in a driver cutout can lift the box (15mm BB), add the drivers and you really would like 2 guys to carry it.
dave
In general i do not like side firing drivers and omni and planar ... i much prefer only front firing speakers Like a cannon shooting music to me only in the sweet spot I do no listen to music walking around in my room
I know that with your solution vibrations will be nulled But there must be another way And i think it is adding weight
If i could find it i would try very heavy steel backing rings bolted on the woofer basket
https://www.acu-tech.com.au/wp-content/uploads/2018/07/Backing-Ring-664x498.jpg
just to add mass
Please look at the video above mentioned at 14:00 I would love to get your valuable opinion
It is a very strong statement I was literally shocked And worried
At the bass frequencies involved it does not matter what direction the woofers face, it will still be omnidirectional.
2 woofers in each box, 2 boxes.
dave
Hi ! thanks a lot indeed I have seen some polar graph in the web
https://www.researchgate.net/public...a-commercial-loudspeaker-Visaton-WB-10-11.png
the dispersion up to 500 Hz is almost spherical 😳
I see many many totl speakers from various brands using the scheme you mention
One of 1st example i remember were the old AR9 ... if i am not wrong the 1st cut is at around 200Hz ? well below the 500Hz
so a good 3 way can have two woofers in parallel ... but not 4 ohm like i read the old AR9 I listened to them at a guy's home Using a valve integrated the bass was not coming out from the speakers It is strange that 4 ohm drivers are so popular Why ?
I would put two 16ohm in parallel instead
Hi sorry but i really have to ask advice on this ... woofers in parallel mounted back to back
This solution would avoid most of the vibrations issues
I wonder which could be the frequency upper limit that can be set ... i am looking at this
https://www.ravepubs.com/wp-content/uploads/2021/11/loudspeaker-1.jpg
the 180° dispersion at 500Hz looks to be at -3dB respect to on axis ? better to stay lower than that ?
A friend of mine bought a pair of these
https://www.quotidianoaudio.it/wp-content/uploads/2015/02/phantom.jpg
i am a little puzzled by them ... i would prefer a passive solution with a separate amp However I like their compactness a lot indeed
I listen nearfield
I listen nearfield
A skecth of what you mean?
dave
https://www.lbtechreviews.com/wp-co...ivid-Audio-Reaction-Cancelling-bass-units.jpg connected in parallelA skecth of what you mean?
dave
I have understood that using a single powerful woofer could make the cabinet construction a very challenging task
the brand is Vivid Audio from Australia?
what has impressed me is to understand that with this arrangement the cabinet does not need to be massive This is very good indeed
i have looked at some polar dispersion graphs and i saw that at 500Hz the dispersion at 90 degrees is down of just - 3dB
it is not a viable concept for a 2 way only
3 ways are needed and also a cone midrange
problem is that 4 identical woofers are needed
and good woofers are the more expensive parts usually
Hi i am very sorry Please excuse me Great speakers for sure but high end products are quite out of my reachVivid is from South Africa,
Thanks a lot I have found them https://www.planet10-hifi.com/planset/TysenV2-promo-171217.pdfWe have a 2-way with push-push woofers. Tysen V2,
dave
Very nice indeed
- Design & Build
- Construction Tips
- Learning the basics of speaker cabinet design
