learning, building and testing tube amp
Hum again??
I just hooked up my SE 6bq5 in the chassis (new layout compared with the breadboard) and got a lot of hum.
Quick question: Does it matter where the PS filter caps are grounded? I have a 10mf, 420 mf and 80 mf in a CRCRC config with the C's grounded at various points in the circuit. Could this cause humming problems?
FWIW, I am using the same PS system as in the breadboarded version.
Thanks in advance,
Rick
QQ
1.What exactly is a "ground loop"?
Since I don't have a short answer for that:
GROUNDING MATTERS
2. What is the function of a series resistor in the control grid of a tube (grid stopper?)?
It helps to prevent HF oscillation.
Some people tend to build oscillators...for audio use.:goodbad:
On a more serious not, some tubes and circuit topologies are more prone to it than others.
In SS equipment these are called gatestoppers.
Cheers,😉
