Hi, does anyone know where I can source an accurate/original, circuit diagram and correct component values for this amplifier?
If you get the other side of that schematic sheet, it has the physical layout as well. It's available on line but if you can't find it I'll scan it for you. I have an original that came with mine.
The stereo 20 circuit changed a little over time, the early version could be prone to overheating. The two main versions can be found here:
Leak Circuits
You need to identify which output transformer you have in your unit and then use the approriate schematic.
There's lots of Leak stuff on that site, it's worth a browse. H.J.Leak and Co. Ltd.
The hardcore leakies can be found at hjleak : "H. J. Leak & Co. Ltd."
Leak Circuits
Morgan Jones describes the Leak 20 as "noisy"....by modern standards. Perhaps one could chase down & correct such shortcomings via subtle modifications. He (Morgan) also notes the 20 also has " a few corners cut", perhaps this could be rectified as well. The Leak enthusiasts quite probably are aware of such shortcomings. Besides replacing most all caps for age issues, I for one would have custom OPTs made...........as I consider these paramount to performance.
_____________________________________________________Rick.......
any suggestions where one can source a replacement 3watt 100ohm wirewound resistor for this amp? This is the crucial one that drops out if it gets too hot and protects the mains tranny. Lots of different versions available in the uk, any suggestions as to type to go for and supplier?
thanks
thanks
If you mean R21, it is a standard wire wound resistor. CPC, Farnell, RS Components, Maplin Electronics, Greenhams almost anywhere will stock them.
W21 100R JI - WELWYN - RESISTOR, WW 3W 5% 100R | CPC
The Leak outputs are the best part of the amp. That's one area they didn't skimp on.
I agree. OPT's are certainly the best part of most medium-to-high level British vintage amps. Generally, they only need some improvements in the power supply.
- Tubes / Valves
- Leak stereo 20
