LEAF Dual 9038Q2M VS Gustard X16 pictures inside )
Hi, can somebody tell me what caps are those 16V 220uF? Brand, series? Also those in between the op amps? 🙂 I have ordered this amp for a price of 150Euro and want to get maybe the best out of it with the change of op amps and maybe changing some of the components if possible for some better ones as an upgrade. Thank you 🙂
Yes, op amps change will be the first. from your photos I can see some Elna RF caps (4 bigger smd caps by the BT module) but I cant see what are those other SMD caps mentioned in the previous post. also the after buffer op amp caps. I know, that you don't have this unit, but maybe somebody can answer those questions. If not I will write down some parts that are going to be replaced and or upgraded to get the full potential out of it. I have some WIMA caps in mind as coupling caps 😉
