Leads for ISCO PS?
ethermion said:
Banana plugs fit nice and snug in mine. ...
You probably have a 494. Here is a manual for it.
http://www.eisenhower.org/eric/isco/494.pdf
Thanks for the quick reply! Yes mine is a 494, purchased after seeing it mentioned here. It will be an adjunct to my Heathkit PS which can only supply 100mA @ ~425V. I have already downloaded the manual, thanks again.
I have a couple cheap banana plugs which I won't use and a few more expensive ones with metal bodies (also not good for this). I'll have to lay hands on some nice insulated plugs.
To be honest I don't see myself exploring the upper voltage levels but who knows what the future might bring?
I use leads from probemaster:
http://www.probemaster.com/testlead8000.htm
See 8026S or 8010S
Nice snug fit, and I use the spade lug to attach to my work.
The 9100 series has a retractable shroud, which might be more safe, but I have not tried it.
Both series are good for 1KV working voltage; well within my needs. Not expensive at all and very nice quality.
Actually, isco was very helpful with the schematic. Maybe they have leads for not toooo much...?
-e
