After several years of good service as a sub amp, my Leach amp began to produce a low-level hum in one channel. This hum continued to develop and increase to unbearable levels. I've replaced the diode bridges (dual mono) with no improvement. I know I have a problem...with no input signal, the affected channel drives the woofer cones to full extension (outward) along with a hum. Looks like a DC signal to me. What should I check, the ouput transistors? And how?
Leach Amp, NO Problem
jackinnj was correct about the bum filter caps. I changed them to a set of 50V. I consider this temporary and will upgrade to at least 63V.
Thanks Jack!
I then discovered a ground loop. Prof. Leach's rec's were to use a CATV isolation transformer and remove all but one of the 3-prong grounding plugs in the system.
Works fine! This was the first time I had encountered a ground loop-so I didn't know anything from experience. A web search provides a bounty of info.
Thanks Jack!
