a suggestion
http://www.electronix.com/catalog/default.php/cPath/6
Electronix Corp.
Fairborn, OH, USA
2SA1302 @ 1.49
2SC3281 @ 1.09
I bought 16 pair. The freight was $6.60. The cost was just under $3/pair, delivered. They "look" to be the real thing. I haven't hooked them up yet.
Tad, ygm
Electronix Corp.
Fairborn, OH, USA
2SA1302 @ 1.49
2SC3281 @ 1.09
Tad, ygm
Electronix - Electronic and computer parts and service supplies
Electronix Corp.
Fairborn, OH, USA
2SA1302 @ 1.49
2SC3281 @ 1.09
Tad, ygm
These have not been manufactured in years, sure their the real thing?
Tad these are a reasonable price, untill you parallel the to get 5W.
Digi-Key - P2.0W-3BK-ND (Manufacturer - ERX-3SJ2R0)
would 3W cut it?
would 3W cut it?
toshiba
Re:
2SA1302 @ 1.49
2SC3281 @ 1.09
Re:
2SA1302 @ 1.49
2SC3281 @ 1.09
All I can add to that above is that I bought them 2 years ago. I still have them, hoping to put them in this amp. The listing is active and the price hasn't changed. I'll report when I hook them up.sure their the real thing?
Luke,
I would probably use the 3 watt Panasonic resistor if I was sure they would be reliable. The First Watt amps running Class A are pushing some fairly large currents and they have been in operation for quite some time.
The Mills at Digikey in 50 lots are less than 2.00 dollars which I guess is something I can survive.
I bought some 2sc Sanyo CRT small signal transistors for the frontend at MCM electronics. They were less than 50 cents each. They have 300 Vceo, and real good Ft,Hfe and less than 3 pf. Also got some 1/16 heatshrink to reconfigure the leads for what we have.
I have gotten most of the BOM laid out at Mouser and Digikey. All for less than 100.00 dollars. NOT including the power supply. I have a nice pile of aluminum at pre 2010 prices in the shop ready to cut.
Need some time!!!!
Tad
Need some time!!!!
Tad
Luke,
Need some time!!!!
Tad
How about posting a copy of the Mouser and Digiy key oder forma with part number, etc?
Buy the way, here is a source for the 0.47, 5W resistors if you can't find them elsewhere. They are wire wound. Maybe not so good?
RCD Components - 160-R47-JBW - Resistors - Passive Components - Allied Electronics
.47 5 watt 1% wirewound non inductive resistors
Here is a link for high quality components for the leak clone project, the majority of all passive components is available at this site eventhough they cost a little bit more.
Cheers.
http://www.partsconnexion.com/product11345.html
Linvalb
Cheers.
Linvalb
HIndex Quantity Part Number Description Customer Reference Backorder Quantity Unit Price
USD Extended Price
USD
1 50 P330BBCT-ND RES 330 OHM CARBON FILM 1/2W 5% 0 0.06060 $3.03
2 30 P10BBCT-ND RES 10 OHM CARBON FILM 1/2W 5% 0 0.09500 $2.85
3 10 P100BBCT-ND RES 100 OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
4 10 P33BBCT-ND RES 33 OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
5 10 P1.2KBBCT-ND RES 1.2K OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
6 10 P2.2KBBCT-ND RES 2.2K OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
7 10 P1.0KBBCT-ND RES 1.0K OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
8 10 P12KBBCT-ND RES 12K OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
9 10 P22KBBCT-ND RES 22K OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
10 10 P220BBCT-ND RES 220 OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
11 10 P11KBBCT-ND RES 11K OHM CARBON FILM 1/2W 5% 0 0.09500 $0.95
12 4 MRA05-10-ND RES AUDIO 10 OHM 5W 1% CERAMIC 0 2.97000 $11.88
13 2 3296Y-502LF-ND POT 5.0K OHM 3/8" SQ CERM SL MT 0 2.50000 $5.00
14 4 338-1068-ND CAP 10PF 500V MICA RADIAL 0 1.07000 $4.28
15 2 338-1093-ND CAP 39PF 500V MICA RADIAL 0 1.07000 $2.14
16 2 338-1082-ND CAP 180PF 500V MICA RADIAL 0 1.46000 $2.92
17 24 MRA05-.47-ND RES AUDIO .47 OHM 5W 1% CERAMIC 0 1.89000 $45.36
ere is what I have so far, If it takes
USD Extended Price
USD
All of the resistors were chosen to fit where they need to go. They are the correct length and ohm value. Dr. Leach in his article always said 5% resistors would work fine. If you check each before soldering they usually are closer to 1.5-2 percent. They are also CHEAP. I gave up on high priced parts when I did not hear any difference. Anyway use what you like or not.
If I can find the BOM from Mouser I will post it. Kind of got lost on the website. There are much cheaper and better parts but freight will be murder.
Has anyone checked on the heatsinks? Again, barrodboss on EBAY has some nice sinks for a good price and very good service.
Tad
Tad
Tad,
Thanks for posting your BOM, I like the MRA-5, does Mouser have an equivalent?
I don't suppose you got a couple of spare 2sc and 2sa sanyo transistors?
the 1Uf film caps have quite a small pitch. Anyone got a part for these. Also never used the little round fuses before, are these readily available?
THL audio
Tad?
A quote from THL Audio:
My currency converter says this:
25 @ $0.473
50 @ $0.442
100 @ $0.4105
200 @ $0.379
Tad?
note the payment fees and shipping costs are not includedRe: Fukushima 5W, 0.47 ohm resistor, silver mica caps
...From:thlinfo <info@thlaudio.com>
View ContactTo:Ed LaFontaine <gelafontaine(at)yahoo(dot)com>
[FONT=Helvetica, Arial, sans-serif]Hello,
Thank you for your mail.
We quote below for your ordering.
Price to add 2% card fee when pay by card or 5% handling on Paypal.
To enter order by card payment, please use our fax order form
for return of shipping
Vincent Chang[/FONT]
On 2010/4/13 上午 09:59, Ed LaFontaine wrote:I would like you to price Fukushima 5W, 0R47 resistors in the following quantity:
25........NT$15/pc
50........NT$14/pc
100 & ..NT$13/pc
200.......NT$12/pc
25 @ $0.473
50 @ $0.442
100 @ $0.4105
200 @ $0.379
Thats reasonable, but the problem with multiple suppliers is the freight becomes your biggest sinlgle cost. Are these resistors good are they?
I certainly understand the question. For this and my posts above. It keeps all of us on our toes. 😉Are these resistors good are they?
YMMV, buyer beware...I have no affiliation or first hand knowledge with which to answer your question.
A search will find references to these resistors on this forum as well as the availability of them in other vendor's offerings beside what appear to be "acceptable/good" products.
I will add that one of the points I want to make is for the establishment of some perception of the "real" worth of these parts. Sure, I can find somebody willing to sell me something for $2. I've got the time, and my $$$ is precious, so I'll try to find the same for $0.50
1uF MKS/MKT are available in 5mm pin pitch.the 1Uf film caps have quite a small pitch. Anyone got a part for these. Also never used the little round fuses before, are these readily available?
I hear that one manufacturer makes an MKP in this size. It will be much bulkier than MKS/MKT. Check footprints of all before ordering.
The round fuses are available, but I could not find the fuse holders in the UK.
I soldered these fuses direct to the PCB. Be careful, particularly with start up currents, they are difficult to remove (PTH and heavy copper trace thickness and thick PCB all increase the skill required to remove these without damaging the PCB).
Luke,
The Sanyo transistors 2sa1371/2sc3468 which I have ordered are about 40 cents apiece from MCM electronics. If you look up the specs on these and you are interested I will be more than happy to ship them to you. The 2sc is back ordered until the middle of May, but still will be available.
Let me know and I will place an order for them. The 1/16 heatshrink is 1.69 for 4 feet. I do not know what that is in metric.
If anyone can find a high voltage transitor for the TO-92 position with the excellent specs and FOOTPRINT that would be nice.
I am going to keep the mje340/350 and drivers per the BOM. They have specs well within reason and I have some on hand.
Ed lafontaine,
I did not receive any money in my paypal account with your name on it that is why the boards were not shipped. I plan to send out a set once all of the international and domestic units have arrived. I have four boards and will part with 2 of them to fill your order. If the funds do not show up at paypal I have to assume that those persons dropped out. I also had a hard time placing legitimate names to the names we use here at DIY audio. It can be difficult.
I also have 10 of the Leach 10 transitor boards left over if anyone is interested email me.
Tad
Ed lafontaine,
Tad
- Group Buys
- Leach Amp pcb group buy interest
