Building a Leach Amp version 4.5 and have a question regarding L1:
Okay if the wire for the inductor and the resistor wire are connected at the PCB as shown?
Or, does the inductor need to be soldered to the resistor leads above the PCB?
Does it make a difference? Current should flow correctly through the resistor and inductor or am I over thinking this?
TIA!
TIA!
