The light from any source will contain noise: fluctuations in light level. This is not just a quantum matter but a thermal noise matter. It is unlikely that this will have any significant effect on an LDR volume control, provided that the supply for the LED is not itself unusually noisy. Those who claim otherwise need to back up their claims with some combination of careful calculations, measurements and well-designed listening tests; as far as I know this has not yet happened. Hence the main issue with LDR controls is the small amount of signal voltage nonlinearity, which will add a little low order distortion irrespective of the light source purity.
Joined 2009
do ldr operate like some form of amplitude modulation device on small signal levels, since light is wave as seen by qm?
sorry if dumb question, since lounge...thanks
The wave nature of light itself cannot modulate the resistance of the LDR. first off the frequency is so high that there are no physical processes for it to interact with other than transferring its energy to the electrons in the material. secondly the energy level of a single light wave is too low, it takes trillions of these waves of light to create meaningful change in the resistance of the LDR and these waves are not in phase with each other unless using a coherent laser source
so by using mixture of different laser "colors" or similar to control ldr one could not modulate/switch ldr on very high freq as resistance change frequency is lower than light wavelengths?
it would be nice to at least know what is maximum freq or rise time or whatever it is for ldr for audio use.
i realy dont know how ldr works, sorry. judging by your posts probably something that is got to do with heating resistance element.
LDR distortion is almost entirely 3rd order.
If you work a common LDR at several volts in and low loss the 3rd is very audible.
As general theory suggests, 3rd falls off quickly with level and 0.1V doesn't sound harsh.
LDRs are quite slow but the specifications must be cleverly corrected to your impedance and light level. It is usually ample to know that they won't respond much to light modulation over 200Hz (certainly to to "light frequency"). In manual control, stray 50/60/harmonics in LED power can be annoying (better when we used dim incandescents). In limiters, signal ripple could be audible, but several popular limiters used no sidechain filtering at all, however with selected slow-release LDRs.
For my application I use D-cells and are voltage regulated -simple, steady and quiet. Four optocouplers; plus 3 LEDs, 2 as indicators and 1 to light up a DC voltage meter and that's about 2+ years of use before battery replacement. I'd say an average of 2 hrs/day of use.
Replaced a Musical Fidelity preamp, now bi-amping using an Aleph 3 and Zen v4j on PSB tower speakers, and have not looked back since ..
- Member Areas
- The Lounge
- LDR atennuators
