I have been looking for suitable LDO regulators for this DAC project,as it will be battery powered for portable use.
I would value some input regarding this device:
http://www.national.com/pf/LP/LP2986.html#Application Notes
Not having much experience with regulator specs[or electronics in general
] the various specs do not mean a whole lot to me.
Cheers
Setmenu😀
Cheers
Setmenu😀
I've used the REG101-5 for the TDA1543, Tent XO and logic chips.
Very low noise, small (SOT23-5), low drop.
Hi Rudolf
Thanks for the reply😀
They look like great little [VERY little] devices, the lack of cap
sensitivity is also very appealing.
I could not locate the 101s in the uk but found 113s to have pretty good spec also.
I can easily obtain these.
Cheers
Setmenu
Cheers
Setmenu
rbroer said:I've used the REG101-5 for the TDA1543, Tent XO and logic chips.
Even Burr Brown specifies noise in the time domain without specifying the BW
yuck......
Rudolf, did you measure the noise ?
Ciao
TI REG101-5
I didn't Guido. Limited in tools.
Do you want to measure it Guido ?
Got a board using this regulator and a socket for your XO. 😉
yuck......
Ciao
Re: TI REG101-5
Hi Rudolf,
I use a preamp (AD 797) and my HP3580A spectrum analyser. If you prefer to send the board with the reg 101, I am willing (and curious too) to measure it.
Cheers
Hi Rudolf,
Cheers
