LCY 130- ribbon tweeters
Pair of sweet sounding LCY 130's. One has a "bad" ribbon. Sounds fine at normal volume but rattles slightly when pushed. It you listen at moderate volume levels you will never notice this. Was used for nearly 2 yrs exactly the way you see them. Like liquid silk. New ribbons are available from Madisound for about 20.00. Not sure if they will let you DIY or you need to send it to them.
Foam gaskets have a couple chunks missing.
link to specs
215.00 shipped to CONUS in original packaging
LCY pics
Some pics of these tweeters. Way above average bang for the buck here tweeter shoppers! If you need to run these at higher SPL it's still an easy fix.
