LCD help needed !!!
i have a question about a lcd ...
Which adjustments do i have to make before i can use a lcd screen (5") in my projector ???
Do i have to to remove the back.... and tape a fresnel lens behind it???
Or do i have to completly remove back + backlights, before i tape a fresnel lens behind it?????
Or....do i have to do something else ??
BTW: can u use a sony playstation lcd (designed for psone) to use in projector
PLEASE...help me :confused:
thx thx thx .....etc
What I'm trying to say is this. Projection panels are larger and specially designed to be put on top of an overhead projector. Playstation screens are not as they are generally 5 inches. They are also lower resolution 320*240 (standard tv) which means it would be hard to get computer into them and looking good. Most panels start at 640*480 res (computer resolution). 5 inche screen would be good for a large slide projector.
So what you are saying is that if I could get my hands onto an LCD screen that does 1024 x 736 or higher then I could probably get a pretty good picture using a fresnal lens strategically placed in front of the screen and light it up a good 30,000 lumens?
Mitch
