http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=75417&item=5754776964&rd=1
that is the link.
the lcd is 1.6 but it has 800x600 native resolution
do u guys think i coulf rig this up and get it working
that is the link.
From some of the things I've read this may only be overheating due to a clogged air intake filter or the lamp is dying, but I'm far from an expert. The thing that I would worry about is that there is no readily available information about it, usually projector central or a quick search will give some info.
all i want to do is take out the lcd from the projector and insert it into my diy projector. is it possible?????????
u will be stupid to do that
the LCD is very small. when the bulb is like 10x bigger
and the contrast is 100:1 thats terrbile
Lamp: Type:
280W Metal Halide
Life: 1300 hours
Quantity: 1
Display: Type:
1.3" PolySi LCD
Native: 1024x768 Pixels
Maximum: 1280x1024 Pixels
Aspect Ratio: 4:3 (XGA)
here is the other one i am looking at. but you are saying it wont look good if i use all of my current optics
280W Metal Halide
Life: 1300 hours
Quantity: 1
Display: Type:
1.3" PolySi LCD
http://www.projectorcentral.com/Polaroid-Polaview_315.htm
that is the whole specifications.
and remember i am just trying to get something better than the ps1 lcd
I dont see any reason why you couldnt use a projector lcd just you would have to use a diffrent condenser???
No expert but it should be possible, another problem is that the driver board for the projector are usually designed to "not work" when the bulb is off
Just my 1p 😛
Just my 1p 😛
- General Interest
- Everything Else
- The Moving Image
- LCD
- lcd from a bbroken projector
