lcd from a bbroken projector
From some of the things I've read this may only be overheating due to a clogged air intake filter or the lamp is dying, but I'm far from an expert. The thing that I would worry about is that there is no readily available information about it, usually projector central or a quick search will give some info.
Lamp: Type:
280W Metal Halide
Life: 1300 hours
Quantity: 1
Display: Type:
1.3" PolySi LCD
Native: 1024x768 Pixels
Maximum: 1280x1024 Pixels
Aspect Ratio: 4:3 (XGA)
here is the other one i am looking at. but you are saying it wont look good if i use all of my current optics
I dont see any reason why you couldnt use a projector lcd just you would have to use a diffrent condenser???
No expert but it should be possible, another problem is that the driver board for the projector are usually designed to "not work" when the bulb is off
Just my 1p 😛
