hi, i have just started digging in the diy projector hole
And i got a question..witch way gives the best final picture quality, to build a projector with a LCD display or with a projector display panel?🙂 🙄
Lcd Display is way better
Hi
An LCD Monitor has a higher contrast Ratio and better Resolution than most panels.A panel has a contrast Ratio of about 60-150 when an LCD monitor can have 250-450.An LCD monitor is the way to go for better quality but a panel is good if you are new to the projection stuff and want to experiment.My choice is the LCD monitor for best results.
Hope this answers your question.
David
Hi
David
LCD from a monitor, no question. The contrast ratio, response time, resolution, and brightness are worlds apart. Of course the higher end projection panels are very nice and require little work.
A panel from a monitor will give you a dvi input as well, for the best image quality from a pc based dvd player.
Check the tutorials on th NEC 1545 and Nec1560M, both of these are relatively easy to disassemble(I havent tried yet, but I will soon), and the price is right. The specs on the 1560 are he best I have found yet, when you factor in the price and the ease f taking it apart.
Good Luck!
Good Luck!
thanks reaely much guys! What is the monitors(NEC 1545) realy made for? Like a smal gaming display in the car or something?
and what is a dvi input?
Both of these monitors are 15" monitors that have to be disassembled. There are 2 threads showing how to do just that. I will be selling my sharp qa-1150 on ebay. It is a lcd that simply sits on top of the overhead projector. It is nice, but the monitors are so much higher quality that to see it is astounding!
DVI input is used to plug the computer that has a dvi output(generally included on a ll newer video cards) to the monitor for
the highest quality output.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- lcd display or panel?
