I'm not sure where you get that from. The Wima MKP are polypropylene caps. That's one of the lowest loss dielectrics and the one that contributes the least to distortion.
~Tom
I've notice when used in high impedence circuits ( tube circuits mostly) they have too much inductance that messes with the miller capacitance of the tube (inter electrode capacitance)
the dielectric is correct. But their construction techniques is flawed.
the balanced outs seem to have been modified weather it is an OEM mod, I don't know. I don't remember those wires when I looked at one many years ago.
Well, I have no problem at all trying the preamp without those wires in place. I just wanted to do one thing at a time and it seems the diodes need attention first. Thank you for the info on the Wima's too.
diodes doesnt matter as long as:
fits
has enough current capacity
can take the voltage.
this is way over kill for a preamp but they will work great if they fit.
MUR1100ERLG
fits
MUR1100ERLG
I have tons of space, those will fit fine. I wasn't sure what would work in this location but if those are overkill... perfect. The other diode I looked up was a zener diode.. does it matter?
Thanks!
Thanks!
I totally forgot I have these on hand from another project that is done;
Digi-Key - CSD01060A-ND (Manufacturer - CSD01060A)
Digi-Key - HFA16PB120-ND (Manufacturer - HFA16PB120)
The first one is smaller and would fit easier, but i could squeeze choice B in there too if needed.
Evan
Evan
Ah crap i just looked over the pics. The wad of 3 zeners is a voltage reference. He tripled them up because zeners cant handle much current. From what it looks like, those are used to make a high voltage regulator.
That being the case you need to find the voltage of the zeners and replace them with the same voltage.
HeadWize - Project: Designing an Opamp Headphone Amplifier (A HeadWize Design Series Paper)
Odds are its something like figure 20. So what ever those zeners are, is what the regulator is going to put out.
Zener Controlled Transistor Voltage Regulators - Electronic Circuits and Diagram-Electronics Projects and Design
well lets find out if the wad of 3 are zeners since you have one out to measure already.
testing zener diode-easy test method
Electronics Tips: Measurements: Testing Diodes and Transistors
For all i know they just look like zeners but are really just standards.
that 12b2 could stand for 12.2 volts.
Alright, I will do that when I get home. As an aside, I kinda chuckle whenever I see the word zener, a child at heart I suppose. lol
Thanks!
Evan
Thanks!
Evan
Lazarus equipment
Hi,I have Lazarus pre-amp- Cascade classic and 2 Mark III mono amps.
Does any one know where I can get schematics fro these equipment?
Additionally, My left Chanel has some noise/Hum.
Also, does anyone know about any up-grade to these equipment. I purchased them back in the 80's.
Would appreciate replies.
jush501@yahoo.com
jush501@yahoo.com
- Tubes / Valves
- lazarus preamp hums even with volume down and no components connected.
