Here is my latest project a class AB 500 watts peak into 4 ohms amplifier in a PC case.
It has an LTP with CM and CCS, a VAS stage with CCS, a Vbe Multiplier.
It has a driver stage then 2 pairs of bi-polar output transistors.
Sound is very clean with plenty of low end.
Underneath the PC case is my amplifier test bed. It uses a 2 amp transformer in case of shorts, this stops output transistors blowing if a fault occurs.
If I power up an amp and the transformer grumbles I know there is fault.
In the background there is a 1980 Maplin 50 watt amplifier pcb.
