Lase elx118p question
Good day,
Item link
Replacement Amplifier Module Electro Voice EV ELX118P Power Sub Speaker w/ DSP 653753247361 | eBay
Decided to get two of these modules off ebay at 15 a piece, can anyone give me any type of information if this can work if I use it on a b&ctbx100 15 or 18 In a tham 15 or 18 box or a bass reflex box ? I know it says 500wrms at 8ohm I don't know if it does that. Really really appreciate the feedback. Again I know it's a small amount of power but I would just rather not have a bunch of processors and heavy amps to set up and move with to stick to Powered stuff plug and play.
Just for some context I already own a pair of the eV zlx-12p tops and I just want two separate subs to go with them for a small home entertainment system. Would like to get it to play generally 35hz( I know it's low idk if doable) to 100hz(idk if doable)
Ps just want something simple to build to give me a bit of low end responses.
Help anyone, with a preferred box or lf driver... Plus I can use in small open areas and maintain some OK sub range frequencies
Yes that will work but you don't need a TBX with that amp... kind of a waste. If you have plans to upgrade the amp at a later date then of course that changes things but if not something like a Eminence Kappa ProLF or equivalent would do the trick and save you some $$.
That appears to be a nice little amp, of course 500w isn't much these days and the amp isn't much to look at but that is the story with digital plate amps. The EV ELX amp isn't any more impressive looking and it doesn't have DSP so that one is better in that regard, and looks like the processing has enough flexability to blend with the ZLX boxes.
