I'm working on an animated guitar cabinet- think Leslie, that'll be close enough for now- and I'm wondering about noise and shielding and such.
This is being designed from the ground up. There's a nice cavity in the base of the cabinet that seems to be begging for the tube amp- a designed-to-fit amp with a preamp, not a Leslie amp.
However, the 24v AC variable speed motor that animates things is right there at the base. It operates from about 40-200 rpm and everywhere in between.
So I'm concerned that if I try to put the amp in the base, it will tend to pick up noise from the motor and play it through the speakers. There's certainly a place to put some shielding, but the motor would be within inches of the amp.
I notice in a Leslie amp, there is no preamp- it takes a signal from the speaker out and just maybe this is how they get away with putting those two motors right next to the amp, with negligible issues, and no shielding to speak of. Conceivably I could put the preamp up towards the top of the cabinet, which would be handy for inveterate knob-twiddlers, but then I'm exposing it to the vibrations of the speaker and stringing out some longer wires that are going to be vulnerable to noise as well.
Any insights or information here?
Thanks,
Ted
Thanks,
Ted
