I juste got hold of a large cap, 34 000 micro/55 V, very cheaply.
But is there anyway I can use use it as a stiffening capacitor since I only got a one?
In case you are wondering, "These low inductance Maxwell pulse caps are each rated at 70 uF @ 12 kV, and 100 kA peak, and they weigh 165 pounds apiece".
Sorry this is off-topic, but I saw "large cap", then had a giggle
those big ones look like from a laboratory where they do research for pulse techniques for example to blow up concrete by attaching high voltage to big wire that´s inlayed in the concrete.
we got the same caps in university for that purpose.
(funny to see professors turning into children and playing around with lightnings and blowing up things)
If the voltage rating is higher than voltage between rails, I don't see a reason why you couldn't use it between rails. I presume that cap is an addition and you already have a ground in the circuit.
