Lanzar 4000D
Joined 2009
I'm working with a optic drive 4000D
Here is the problem that I'm having, IC4001 has both low and high signals coming out and going into pin 12 and 14 of IC IR2010, but only the low signal is coming out of IC2010.
I know I need to installed audio mosfets at the low side to get the high side signal out, but when I installed 2 mosfets one in the low and one in the high side, Both mosfets got destroyed.
Is there a way to cheat the IC2010 to force the high signal out?
Or is there some one that can provide me with a schematic?
Here are picture
Hey Perry, I apply the voltage to board, and now I have both low and high signal out.
I soldered in all audio mosfets transistors, and now when I apply power the amp goes into protection mode after the relays click on. any idea?
with reference to the battery terminal ground there is -89 volts before relay click and
-94 volts after relay.
with reference to the fb ground { pin 7 of driver board } there is +84 volts before relay and +97 volts after relay.
