Hi guys, I've got a Laney TF-200 (tube fusion), the amplifier features an ecc83 valve in the preamp, nasty surface mount TL072's, 1 clean channel and 2 drive channels, with separate eq's for clean and distortion.
The speaker (an HH invader speaker) farts out loud when the amplifier is running any of the two distortion channels and I set the bass knob to 12 o' clock or more and the master volume past 12 o' clock.
I have tried two different 8 ohm speaker and the same thing happens, but they doesn't fart out as loud as with the HH speaker.
Is there any way to modify the power amp section to fix this? Or will I just need to buy a better speaker?
Thanks in advance.
Thanks in advance.
