I believe Generg is working on a mu follower.
My CCS is just as you suspect, a self-biased IXYS with a 1 Ohm source resistor.
Well, I would prefer the CCS solution over the choke load one. I have the IXTH devices on hand.
How about a balanced solution? The way Papa did it in ZV1: Balanced Lite (you gotta love the play on titles!). Gets rid of the output cap, more power, less distortion.
This SIT is just really a part for part replacement for the MOSFETs, with a few changes in part values in the circuits. You could probably go through the entire Zen series, right?
It certainly has potential. 🙂
I have something balanced on the workbench right now, but I'm not going to preempt myself this time.
In the sense that they are both transistors, yes.
Most of the Zen series uses enhancement MOSFETS with feedback, and these SITs don't exactly have a lot of gain to spare. And, of course, you must account for their need for negative bias voltages (Depletion Mode).
But, from a high-level topology standpoint, yes, you can plug them in and see what happens.
do not expect him so soon ;
too much variants to pick one from ........
I had some exchange with ak4396 concerning the MU follower! he simulated a solution and I was impressed by his skill....😱
But all the honor is to him to publish his idea......!😀😀
i still don't know why in my amp the fig 11 sounds better
anyway , the Sit sounds good and is quiet now so thnank you again michael🙂
here comes my simple Mufollower circuit......🙂
you can alternate the connection of the 10k Pot coming from point A, the drain of the SIT, to point B, the source of the SIT......
as far as I can say B offers more gain and more bass to my Tone Tubbies and in simulation offers a bit less distortion.
I will continue my experiments when my "experimental" heatsinks come and I can compare with my standard constellation, crippled F4. (waiting now for four weeks ..)
🙂 ohh i forgot , when i rewired my Star gorund i had hum back again in the speaker. so i put the bridge - wire at few inches form the starground ( , source res, bypass cap , rca ground, speaker ground) and the hum disappear .
thanks Zen Mod! and thanks for your help on the way.....!
it wasn't my intention to bring that ..... I meant on your overly expressionistic way of schm drawing ( which reminds me on someone else's )
Yes, always try to copy Nelsons schm and your kind of drawing to get all the magic of the circuit......😀😀😀😀
thanks Zen, I am sure Papas scheme is in a much, much better way working......😎
but you are right we have the amount pot....... to fullfill our hopes........!😛😛😛
and you see we have with the amount pot even a Babelfish element introduced......
I know a couple of readers had their hearts set on something active, so here you go:
L'Amp CCS Addendum
Very nice performance, this could be turned into something really interesting 🙂
I guess the slow rise in distortion at 50Hz are due to the relative low output capasitor showing its limits?
Hi guys!
Hope everyone is doing great with their amp builds 🙂 I haven't given up on my amp, hehe.. I'm waiting for some inductors to arrive, 4x 28mH (430mΩ DCR) and 2x 150mH (1Ω DCR), both @ 3ADC.. not sure how i'm gonna use them yet.
Maybe an L-input PSU, or CLC and perhaps exchange the big 200W resistor on the Drain for an inductor? =)
I'm pretty sure i'm gonna go for monos and not PSU-box + AMP-box as my PSU might be quite heavy with my 10kg transformer (which is adjustable from 2-130V @ 2V steps 😉 ) and with an L-input filter for two channels my PSU is gonna weight a whopping 30kg, and not look to nice.
Is the way to go an inductor loaded Drain? How will that affect the output impedance?
And nice builds everyone! 😎
😛 there is something i don"t understand on hte graph thd vs frequency with inductor load.. does it means that with a inductor you don't get bass as good as with the resistor load? as i don't need extra power with my horn what will be improved with inductor load except smaller power supply and less heat ?
- L'Amp: A simple SIT Amp
