Lambda motor vs. XBL^2 motor vs. any other motor
Hello
Not intending to start a war between Nick and Dan, or any fight between the owners, resellers and users of these respective technologies. So please, be polite and informed if you decide to comment.
My starting point is that I'm looking for a driver for a most ordinary home subwoofer in a sealed box. Looking at the 12" Peerless XLS driver, and what mr. Linkwitz has written about it, I can't help but notice the harmonic distortion it produces with a 20Hz or a 30Hz sine signal.
http://www.linkwitzlab.com/thor-measmt.htm and scroll down about halfway.
I'm interested in knowing if either the Lambda motor or XBL^2 motor is addressed at specifically reducing this kind of distortion. That is, 1) at low frequencies and 2) in a sealed box. Or if they, as a side effect of some other primary aim, reduce the harmonic distortion with 20Hz or 30Hz sine signal.
I'd ike to know, how are the design aims of said motors different, and while they surely excel at different situations compared to each other, what are these situations exactly? And, are there other specialized woofer motors, and how would you rate them?
Then finally comes the question whether I should replace, in my plans, the 12" Peerless with the Shiva's newest incarnation or some 12" driver in AE lineup, or some altogether different driver. I like the way mr. Linkwitz analyzes the power requirements of the driver in a smaller than optimal box, and I also plan to use EQ.
I have about 240W of amplifier power to spare (RMS into 4 ohms), so do not suggest any "three inch linear excursion and 2kW power handling" wonder drivers. I also plan to find some kind of a sweet spot with regards to the budget.
Some others drivers with a different then usual coil design is the Differential Drive drivers from JBL these are mostly from there Pro Audio range but you can also find it in there W Gti car audio range, I'm not sure if you can find it in any of there Home Audio/Theatre drivers.
Here is the white paper http://www.jblpro.com/pub/technote/JBL_TN 1-33 rev3.pdf
There are several benefits to the design which the white paper covers.
One benefit is it allows the drivers to still have quite high sensitivity, unlike some XBL^2 drivers I've seen.
Here is a link to a pdf with the specs for the JBL W15Gti if you want to model it up and see how it models, (the enclosure recommendations are obviously for in car so won't have much relevance for your purpose.) http://manuals.harman.com/JBL/CAR/Boxes and Parameters/W15GTi_rev_f.pdf
Hi Thinkcat,
Let compare AV12-X and Shiva-X.
I'd say that roughly, XBL^2 attempts to lower distortion by linearizing the BL curve as most as possible, without increasing mms, with clever design. XBL^2 also help a design to achieve a higher xmax than usual. Le is low at 0.9 mH.
On the other hand, Acoustic Elegance prefer to lower distortion by lowering Le as much as possible. They do that with copper shorting rings by using a full copper sleeve on the pole piece. Le is VERY low at 0.196 mH.
I'd say that both are good drivers, and to me, several notches above the Peerless XLS line. I'd think they would achieve much lower distortion than the Peerless, but then, someone would need to test it.
Let compare both drivers to the good old XLS.
XLS got a Le which is 4.2 mH, poor versus 0.9 mH and very poor versus 0.196 mH. Power handling is 350W versus 600W and 1000W. xmax is 12.5 mm versus 27 mm and 23 mm.
It can't compete, really ! :D
MaVo said:
Double the drivers, which halves the excursion at the same level, equalling lower distortion.
But let's assume the case is that I want two boxes, both maybe 50 litres in size (like Linkwitz's Thor subwoofer). That mostly means 12" or in some cases 10" drivers. How can I, from there on, improve the quality of the reproduced sound? Dipoles are out of the question for now.
If I was contracting for a basement movie theater, I would possibly like very much the B&C 18TBX100, BMS 18N850V2 or McCauley 6174, as suggested in the thread at
http://www.diyaudio.com/forums/showthread.php?s=&threadid=128109
But the case is, I am looking for a good sub for my smaller than average living room. Primary aim is listening to music, i.e. a clean and articulate sound. Movies will come second, or have to get along with what is available in terms of power and displacement.
I've used these for subs in HT and in church's, up to 40x80. Only real problem with this design is it needs some more weight to keep it from jumping in the air. (had to add 10lbs of weight to the inside of cabinet) Sitting on it also works well.....
This design came directly from the good Dr. himself.
jbell said:
I'm a fan of the HSU 12" driver. It is an XBL2 motor, but is an overdamped driver.
Where could I see these drivers for sale to Europe or Scandinavia? On the manufacturer's homepage ( http://www.hsuresearch.com/ ) I could only see complete speakers and subwoofers. Maybe I did not look closely enough, but on a quick second look I was still unable to locate information on bare drivers.
But anyway, for the purpose of this thread, my biggest worry is, that does the ability to play at high excursion somehow degrade the sound quality of a driver? Basically I've began to think that yes, it does.
http://www.diyaudio.com/forums/showthread.php?postid=1587892#post1587892
http://www.zaphaudio.com/lowxmax.html
Therefore I'd love to know, which "famous" or "good" or "well known" drivers are "safe" from this kind of degradation? Are all, some or none of XBL^2 drivers? The new Shiva-X? Original 15" Tempest? Are all, some or none of Lambda / AE drivers? Is the Peerless XLS "safe" or not? Who can I trust these days anymore?
Well, you want to play 20 Hz and 30 Hz. That needs massive amounts of air to be moved, or you will not be able to hear it. You will only barely feel it, by the vibrations.
Yes, usually higher xmax drivers will show higher distortion, but still, you need to factor in the performance/price ratio in this.
You could build yourself a huge array of top-of-the-line Acoustic Elegance TD15M which are 15" drivers flat to 4 kHz with 6 mm of xmax and 98 dB of efficiency with 1 watt.
At 309$ per driver, you'd need 4 of these to achieve the same loudness at 20 Hz versus a single Acoustic Elegance AV15-H which will do the job fine at 219$ per driver.
As someone said earlier here, then you could double up, or more.
Since you're looking at 20 Hz and 30 Hz, you better stick with true subwoofer drivers IMHO. If it's not loud enough or the distortion is too high, then use more true subwoofers drivers. It will be cheaper, louder, perform better and have lower distortion overall.
Would you call Acoustic Elegance TD12H, TD12S and TD12X true subwoofer drivers? Or, would you recommend Shiva-X over these, or any one of these over Shiva-X?
I'm programming with Python at the moment. My aim is to build an easily toyable version of Linkwitz's spreadsheet that will allow me to see and compare the behavior of multiple drivers and multiple box sizes at the same time. At the moment it outputs Gnuplot graphs, and is about halfway done. There will be no user interface for now, i.e. using it will require some programming knowledge.
Why not try WinISD Pro to compare drivers ?
Well, I'd call those TD12H, TD12S and TD12X very high quality midbass drivers than can double as subwoofers if used in large boxes. You may get plenty of 30 Hz but don't expect alot of 20 Hz out of them.
Those drivers are made to play 30 Hz to 1 kHz and more... if you want to use them as subwoofers and go down to 20 Hz, you need to plan a large box of let say, 6 cu.ft and more.
About the distortion, maybe they would be slightly cleaner, I don't know.
I use three different types of "linear BL" type drivers between my main system and my nearfield system. The main system uses an XBL^2 driver with extensive Faraday shielding (Exodus Audio Maelstrom-X) as the main sub and two underhung-coil drivers with extensive Faraday shielding (Aura NS12-794-8A) as filler subs. The nearfield system uses the aforementioned JBL W15GTi. All are in sealed cabinets.
Up to the limits of the least capable driver in terms of SPL (the 12" Aura, which makes sense compared to the 15" JBL and the 18" Exodus) and properly level matched, I am not at all confident that I could even tell the difference between the three drivers. They are all just plain exceptional.
I agree that all of them are a half-step better than the XLS12. (I also have three of those.) That is high praise as the XLS12 is a really, really good bass driver. The difference is hardly enormous, however.
diyAudio Member RIP
Joined 2008
I am not going to discuss which motor type is better as obviously I would be biased, but ask John at AE Speakers for a SB12 if desired. I don't see the specs on the website but I know he can build it. Here are the specs for the 8ohm, he can do a 4 ohm as well. It is designed specifically for 2-4 cubic foot sealed cabinets.
Fs20.9Hz
Qms4.23
Qes 0.64
Qts 0.56
Vas 160 Liters
Cms 0.4 mm/N
Mms 145 grams
Sd 531 cm2
Rms 4.5 Kg/S
Bl 13.9 T/m
Re 6.5 ohms
Z 8 ohms
Le 0.3 mH
"no" 0.22%
1WSpl 85.6 dB (8ohm)
2.83V 88.6 dB (4ohm)
linear xmax ~14mm peak
