Hi Francolargo, I'm very intrigued by your results. Does this mean you have the LADSPA filter working with MPD? Can you do a quick howto, and include some of the settings you used?
Hi @stijn001, I'm just starting my action-list. Fingers crossed there will be no issues! More info coming as soon as possible.
Greetings,
Most of the discussion between page 1 and here related to difficulties using LADSPA filter plugins in alsa with MPD. It didn't work right with all players at first. I'm happy to report that the problem seems fixed. Extra special thanks to @phofman and @miero for their help! In the end, there was a configuration issue in the asound.conf file and correcting it solved all of the problems that we were up against. 😀 As always, please speak up if you find errors or omissions. Again, the important LADSPA filters are from here, where you can read more about their implementation. The simple delay is from Computer Music Toolkit (whose online documentation appears hacked at the moment - http://www.ladspa.org/cmt/ ). Unlike the R.Taylor setup, we are running them within ALSA, which avoids the sample rate conversions needed with other filter clients.
Below is an updated configuration for a 'generic' two way crossover using the Richard Taylor 4-pole Linkwitz-Riley high- and low-pass LADSPA filters. I have tested it to the best of my ability with my current basic setup, but more rigorous testing with decent instrumentation must wait. For now, it seems to run fine and sound fine. The good thing is that no special player configuration is needed - neither for MPD nor for squeezelite. The players' default configurations are very close to optimal. Just use the setup instructions on page 1 of this thread but copy/paste the following text to the /etc/asound.conf file, reboot, double check that the file was read using 'aplay -L' (plugins are listed at the top), and begin experimenting.
Let me comment about each of the individual plugs in the chain. Conceptually, the 'signal' runs from top to bottom of the file. If you don't need a particular function, definitely delete its plug and correct the internal links between plugs, as described.
pcm.!default - do not edit
ctl.!default - do not edit
pcm.filter - insert your desired XO point frequency in the 'controls' box. It is set at 440Hz, which is easy to hear. I will be using mine somewhere between 120-150 Hz.
pcm.eq - many systems could use a bit of boost with low bass or perhaps the room has reflective nodes. An eq filter can address that kind of situation. [Hint: use sparingly above ~200Hz.] If you don't need them, delete the whole cpm.eq plug, and edit the slave.pcm output above in pcm.filter to connect to the next plug in line. That is, within the plug cpm.filter, the line "slave.pcm eq" might go to "slave.pcm delay" (without quotes).
pcm.delay - if your speaker or driver alignments are not optimal, you can delay the signal to any driver that, relative to the others, is located too close to the listener. In my case, my woofers will be about 33 cm in front of the midrange+tweeters. So, I will use a 0.001 second delay on the woofers, and no delay on the high frequencies. I don't know exactly how the delay filters are programmed so I will leave the two "inactive" high frequency delay filters in the chain for now. That will keep the processing more symmetrical. Later when I can set up with an oscilloscope we will see if the inactive delay filters are helping with time-keeping. Again, if you delete cpm.delay, you must link the above plug to the next in line (pcm.speaker) by editing the above slave.pcm line to "slave.pcm speaker" (no quotes).
pcm.speaker - do not edit or remove
pcm.ttable - do not remove This plug straightens out a channel alignment quirk of the BBB/Botic distro in which stereo pairs are not maintained in the channel alignments. Channels 1 (right high) and 2 (left low) are basically swapped. In each line of the table, the first number is the input channel, the second number is the output channel. [The third number is signal strength - not active here]. If you are adapting this configuration to a different system or setup, edit the ttable to correctly route the channels.
CPU draw - perfectly adequate
Using mpc/mpd, I played stereo files from 44.1 to 192kHz through the default system above. Here are the CPU numbers reported by top.
Thus, I'm optimistic that a basic three-way crossover can also be achieved with the BBB. For now, experiment - report back - enjoy!
Code:
pcm.!default {
type plug
slave.pcm filter
ctl.!default {
type hw
card 0
pcm.filter {
type ladspa
slave.pcm eq
path "/usr/lib/ladspa"
channels 4
plugins
0 {
label RTlr4lowpass
policy none
input.bindings.0 "Input"
output.bindings.2 "Output"
input { controls [ 440 ] } # low left [ frequency in Hz (-6dB XO point)]
1 {
label RTlr4hipass
policy none
output.bindings.0 "Output"
input { controls [ 440 ] } # high left
2 {
label RTlr4lowpass
policy none
input.bindings.1 "Input"
output.bindings.3 "Output"
input { controls [ 440 ] } # low right
3 {
label RTlr4hipass
policy none
output.bindings.1 "Output"
input { controls [ 440 ] } # high right
pcm.eq {
type ladspa
slave.pcm delay
channels 4
plugins
0 {
label RTparaeq
policy none
input { controls [ 0 4800 2.0 ] } # high left [ delta dB, frequency, Q ]
1 {
label RTparaeq
policy none
input { controls [ 0 4800 2.0 ] } # high right
2 {
label RTparaeq
policy none
input.bindings.2 "Input"
input { controls [ 3 30 0.7 ] } # low left
3 {
label RTparaeq
policy none
input.bindings.3 "Input"
input { controls [ 3 30 0.7 ] } # low right
pcm.delay {
type ladspa
slave.pcm speaker
channels 4
plugins
0 {
label delay_5s
policy none
input { controls [ 0.0 0 ] } # high left [delay in seconds, wet/dry (0=all input, 1=all output)]
1 {
label delay_5s
policy none
input { controls [ 0.0 0 ] } # high right - 0.001 sec. = ~ 33 cm of sound travel
2 {
label delay_5s
policy none
3 {
label delay_5s
policy none
pcm.speaker {
type plug
slave {
pcm "t-table"
channels 4
rate "unchanged"
pcm.t-table {
type route
slave {
pcm "hw:0,0"
channels 4
ttable {
0.0 1
1.2 1
2.1 1
3.3 1
Code:
Freq. PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
44.1 1027 mpd 20 0 84364 78m 26m S 13.9 15.9 1:37.01 mpd
48 1027 mpd 20 0 84380 78m 26m S 14.9 15.9 1:46.28 mpd
88.2 1027 mpd 20 0 88460 82m 26m S 27.5 16.7 1:58.75 mpd
96 1027 mpd 20 0 88460 82m 26m S 30.0 16.7 2:14.69 mpd
176.4 1027 mpd 20 0 96676 90m 26m S 55.0 18.3 2:50.14 mpd
192 1027 mpd 20 0 96668 90m 26m S 59.6 18.3 3:25.37 mpd
Mini-erratum: In the asound.conf text, the bottom two filters within the delay plugin are the low frequency channels (2 and 3), not high frequency as stated in the comment
Extending BBB/Botic function
Question for Miero:
What would it take to pipe an outside I2S source into Botic's alsa interface? Are there 3-4 pins on BBB p8 that could input into the system?
If we agree that the crossover described above is worthwhile, then it would be nice to share that filtering with other sources (than the output of music player software). Also, diverse LADSPA plugins could be used for many other functions than speaker crossovers. I assume external I2S would be easier to handle than encoded S/PDIF.
For example, with the TPA Wolfson S/PDIF transceiver, BBB could have ready access to a wide range of other audio appliances. Also, ADC has been discussed in relation to BBB, so adding an external I2S input could make Botic/BBB a great multi-function integrator for diverse audio sources. Would adding external I2S input be difficult or simple? To me, those pins on the p8 header are just begging to be used! 🙂
Question for Miero:
The hardware should work as I2S receiver; I've tested it using ADC from Juli@ soundcard -- http://www.diyaudio.com/forums/twis...embedded-audio-applicance-35.html#post4094282
There is only one 4 channel sound controller usable on the BBB (the CPU has two), so it would require to have matched rate/format to be able record & play at once.
And this will not work well if incomming I2S can change rate/format on the fly.
But it could be used quite well for ADC controlled by BBB, and this setup could be used as DSP processor for analog signal.
Thanks, that sounds encouraging. For my personal system, I would like to be able to filter the audio portion of video feeds. Critical fidelity is not the first concern. In fact, I believe all my video hardware is fixed at 48k, so setting that rate as default would make sense. I will check your comments on the other thread, give more thought, and take it from there. Thanks Miero! 🙂
Thanks, for the explanation. For the time being I'm only intrested in the filter function. Now I need to find the time to do some tinkering.
francolargo: notice, delay introduced by audio processing on BBB might be issue if you want use in real-time it for video.
Yes, there is that possibility. If the delay isn't too bad, there may be delay workarounds on the video side.francolargo: notice, delay introduced by audio processing on BBB might be issue if you want use in real-time it for video.
However, I am unsure of my ability to get I2S into the McASP. I am now looking into pin setup but in Botic I see no xxx.dts to edit and I need to understand more about tree overlays and what activates them. And then, how to make the configured pins input correctly to McASP? I see the davinci driver is there, but I haven't looked into that yet. It's a lot for a beginner to bite off! 😕
No need to change device tree 🙂
Using botic5 it should be enough to switch serializer into record mode by writing 'R' into its config slot. I've just updated missing doc on webpage.
For example (playback on data0, record on data1):
echo "IR--" > /sys/module/snd_soc_botic/parameters/serconfig
That sounds great, but I should study more before I attempt this! 😱
I think the master clock input to the WM8804 can come from Cronus, which should align the other I2S clocks on the spdif -> I2S transceiver. But then, Dout from WM8804 - will it go 'backwards' through the isolator and is P9_42 configured for input? I am reading the Derek Molloy book on the BBB and am perhaps overly cautious about GPIO connections.
McASP pins are two-way, but Hermes-BBB & Cronus are not. So you need to attach ADC directly to BBB pins.
3-way crossover in alsa seems viable on BBB
Curiosity got the better of me, so I tried running a 3-way alsa crossover configuration file even though my system doesn't have DACs on all the needed outputs. Because of this, there was some 'channel-seeking' in the output (not nice), but I just wanted to see how the BBB CPU managed. While playing a 192kHz .wav file using mpc/mpd, CPU demand was about 70%. Very manageable and encouraging. Here is the asound.conf file if you want to experiment. Remember that channel alignments may need adjustment using the ttable - suggest using 'speaker-test -c2' and listen for the frequencies on each output channel. If things go wrong, a hard reboot is suggested after asound.conf edits.
If you try this, please share your results and impressions! 😉
Code:
pcm.!default {
type plug
slave.pcm filter
ctl.!default {
type hw
card 0
pcm.filter {
type ladspa
slave.pcm delay
channels 6 # high = channels 0,1; low = channels 2,3; mid = channels 4,5
plugins
0 {
label RTlr4lowpass
policy none
input { controls [ 250 ] } # left low [frequency (Hz)]
1 {
label RTlr4hipass
policy none
output.bindings.4 "Output"
input { controls [ 250 ] } # left mid bottom
2 {
label RTlr4lowpass
policy none
input { controls [ 250 ] } # right low
3 {
label RTlr4hipass
policy none
output.bindings.5 "Output"
input { controls [ 250 ] } # right mid bottom
4 {
label RTlr4hipass
policy none
input { controls [ 4000 ] } # left high
5 {
label RTlr4lowpass
policy none
input.bindings.4 "Input"
input { controls [ 4000 ] } # left mid top
6 {
label RTlr4hipass
policy none
input { controls [ 4000 ] } # right high
7 {
label RTlr4lowpass
policy none
input.bindings.5 "Input"
input { controls [ 4000 ] } # right mid top
pcm.delay {
type ladspa
slave.pcm speaker
channels 6
plugins
0 {
label delay_5s
policy none
input { controls [ 0.0 1 ] } # low channels only [delay in seconds, wet/dry (0=all input, 1=all output)]
1 {
label delay_5s
policy none
pcm.speaker {
type plug
slave {
pcm "t-table"
channels 6
rate "unchanged"
pcm.t-table {
type route
slave {
pcm "hw:0,0"
channels 6
ttable {
0.0 1
1.1 1
2.2 1
3.3 1
4.4 1
5.5 1
pcm.plughw.slave.rate = "unchanged";
What the hell are you guys smoking? Do you ever LISTEN to music or just dick around with this crap?
Very good! The WM8804 data sheet claims that simply operating in 'slave mode' transitions its clock pins to become inputs. So I will supply the 8804 clock from Cronus. ...next week at the earliest...
So as we move ahead, let’s keep our eyes on the prize - to feel, through a very high resolution auditory experience, a greater sympathy with the diverse emotions captured in our music.
@francolargo
Great stuff! Just wanted to let you know even if I am quiet I am watching with interest.
Cheers!
Russ
Cheers!
Russ
Thanks Russ! ...hope these efforts help a few people and lead somewhere interesting... Speaking of 'very high resolution', I just replaced a very-tweaked Legato 2 with the new 3.1. Now I'm singing-along to music that I thought I was tired-of!!! 😀
- More Vendors...
- Twisted Pear
- LADSPA filters for digital crossovers on the BBB
