Both work very well at attenuating the signal.
If your source can drive a lower impedance load, then I'd suggest using a 10k pot.
2.12Vrms (3Vpk) into a 100k pot requires a peak current of 0.03 mA to feed the resistive load.
Using a 10k pot increases that peak current demand to 0.3mA.
Since the parasitic capacitances could demand a further 1mA of peak current, the difference in total peak current is between 1.03 and 1.30mA, i.e. 270uApk.
Go for the lower 10k impedance.
I firmly believe that the volume control should be readily accessible to the listener.
That virtually demands that the volume control should not be located at or near and certainly not inside the Power Amps.
Under the stereo located in the middle of the "Listening Wall" is also not a good location.
Remotes help solve this location problem, but non remotes really need the pre-amp next to the listener with long leads from and to the other gear.
