I have been "inspired" to build a ladder attenuator for my active pre-amp. I have a Seiden 23 position 4 deck 4 pole shorting switch with no instructions on where to solder resistors. Before I order resistors I would like to know what it is I am to do with them. There are four bands of 23 circular solder tags (one around each deck) to receive one end of each resistor. The question is: "What do I connect the other end of each resistor to?"
I can't see anything else which the resistors might connect to save for a single tag on each deck which connects the wiper to the resistor. Having gone through this experience, have you any clue? A picture of a 2 deck version of my 43NEG switch appears at: http://www.tachyon.co.jp/seiden/seiden.html
I don't have any problem with working out the resistors I need as I am using the Goldpoint chart for 24 positions and leaving out one position to make up a 64db 100k attenuator. Would I be correct in thinking I need 92 resistors?
Judging from this: http://www.goldpt.com/schm_ml.html I'd guess you connect all the other ends of the resistors together and connect it to the input / last position on one of the deck and to ground / last position of the other one. Then connect the wipers together and take the output from there.
Wouldn’t 23 positions leaving the last one open require 22*2 resistors? 88 total for 2 channels?
Thank you Peranders & Kermit. I think it is getting clearer.
The wiper moves over 23 positions. Each has a single solder tab. In between either end of the wiper's sweep, between positions 1 and 23, is a position over which the wiper cannot rest. I will call it "position 24". It has a large gold solder tab.
Kermit as I understand it, for each channel, I need a loop of wire connecting each resistor around each deck together. On the first deck, one end of the loop is connected to input and the other to output. On the second deck the loop similarly connects resistors to each other, and one end of the loop is connected to ground(but what is the other end connected to?). Then I join the two decks together using position 24. Does this sound correct?
Number of resistors: 23X4=92
Thanks again guys.
Thanks again guys.
Yup, but you don’t need a wire, just connect the ends of the resistors together.
Here I believe you are wrong. Look closely at the link I posted. You will se that the resistors are connected to input on the first deck and the last position of the switch. You take the output at the wipers (“position 24”).
Yup, and output comes here too.
Hope this clarifies things a bit. Good luck.
L TYPE ATTENUATOR
Setriode,
I hope you haven't started your soldering yet since there may be a few things you need to consider.
-What are you driving with this volumecontrol?
A tube stage? An interconnect to your amplifier?And what input impedance does it have?
-You need to know the input impendance of the next stage and it's capacitance.
-There is no need for that many resistors,you can use a voltage divider with 1 series R per step keeping the grid to ground R constant.
-Indeed : pos. 24 is a stop and your signal input.
-Also it is a lot easier to work on if you had two rotaries of the single pole single deck make before break type.In which case you can than group all R together at the outputleads and connect your output wire there.
You state 4 deck 4 poles? I assume 4 decks with one pole per deck all poles in the same position?
You see if you vary the shunt R you also alter the polarisation of the next stage and the output impedance.
As a consequence of this the freq.responce will vary depending on the volume setting.
This is ofcourse not desirable.
Best regards,
Setriode,
Best regards,
ATTENUATOR
Thks,Bernhard.Sure feels good to be back.
You have me wondering with that 600 R attenuator now.
I've been tinkering with that too together with LC RIAA correction.
But short of buffering both in- and output with transformers or using a variable transformer and rotary switch I can't find an easy solution.
Mindboggling....
Mindboggling....
setriode,
The answers to your questions depend on which type of switch, you have, exactly, and whether you want to build a single ended or balanced attenuator, and have that implemented in either series, ladder or shunt mode.
A breif synopsis:
<b>Series</b>
+ only one switch contact directly in the signal path.
+ fewest number of resisitors
+ constant Zin
+ only needs two decks
- IME worst sounding, esp as you go to greater attenuation because of all the resistors and solder joints in the path.
<b>Ladder</b>
+ only two resistors in the signal path
+ constant Zin
- two switch contacts in the signal path at all times
- 4 dechs and twice the number of resisitors required than a series.
+ IME much better sounding than a series.
<b>Shunt</b>
+ One resistor in the series signal path, so can be very high quality like Vishay S102
+ two decks and same number of resistors as series.
+ all other resistors are in the shunt path so are less important sonically.
? Zin will vary from a max at lowest attenuation to a min value of the series resistor at max att. If your pre can drive a modest value series resistor it should not be a problem. eg Pass pre's, some tube gear won't like it at all, esp the "traditional" crap with no drive capability at all.
+ usually best sounding of the resistive att's if your pre can drive it.
All the schematics for these are on the Goldpoint page, <a href="http://www.goldpt.com/diy.html">here</a> as are the resistor lists.
46 - series
96 - ladder
46 - shunt
Having heard all of them, the S&B transformer volume controls are <i>vastly</i> superior to all the resistive types I've tried.
HTH
Cheers
PS: Frank. Good to see you back. Your sin-binning was a travesty.
A breif synopsis:
<b>Series</b>
+ constant Zin
<b>Ladder</b>
+ constant Zin
<b>Shunt</b>
46 - series
96 - ladder
46 - shunt
HTH
Cheers
ATTENUATOR
People,
"Shunt
? Zin will vary from a max at lowest attenuation to a min value of the series resistor at max att. If your pre can drive a modest value series resistor it should not be a problem. eg Pass pre's, some tube gear won't like it at all, esp the "traditional" crap with no drive capability at all."
And that is where the problem is:drive capability.
This is especially true when incorporating in an existing design as an "upgrade".
The culpritt is that nine out of ten will not have interstage isolation (buffering).
Hence my suggestion of keeping RgIn constant and only vary the series R.
Any frequency response deviation then is only caused by capacitance (which should be kept at a minimum).
Another important point is to keep in mind is that Vg- for the next stage is often derived by RgIn + Rk,the shunt resistor in // with RgIn will alter this operating point for all but one position namely where series R and RgIn are identical in value (6dB att.)
By using dual mono rotaries and a single deck one can arrive at excellent results provided a good cathode follower is driving the interconnect to the amp with low Z.
Moreover two rotaries in a dual mono config. will allow for balance adjustment provided the steps are not too coarse.
Or, if it must be a double deck single rotary you can simply tie the resistor output leads from each deck and take it from there to the cf.(IMHO only the White is good enough.)
Using it this way will also eliminate the expense of a second deck and avoids yet another switch contact in series with the signal.
At the same time it will then also isolate the attenuator from the load the amp see which is kept constant.
Another way to sonic bliss is to use the good old cermet linear pot with a law faking network.
Beats all log.pots I've heard so far.
The trick is to put a system together taking all possible factors into account where you design for minimal drive requirements at normal listening levels.
Not an easy task!
Yep,this boy is saving up for a custom made one with my own custom made silver wire.
Any bankers among you?
Cheers folk,
People,
"Shunt
Not an easy task!
Having heard all of them, the S&B transformer volume controls are vastly superior to all the resistive types I've tried.
Cheers folk,
Volume control.
Hello Bernhard,or anyone else for that matter,
Do you mind to elaborate further on the subject you touched upon?
Before people take the plunge and go for the TCVC (transformer controled volume control,a new acronym?) it would be nice to know how to best implement it.
I consider this a very worthwile issue.
P.S. Bernhard,before you know it you're bound to end up whith a Pultech pre,aren't you?
Ouch,now the word is out...
Frank.
Frank.
Ladders & law faked cermets
Hi Frank,
I'm a DIY newbie, currently considering an upgraded attenuator for an active pre-amp (ss input stage, tube output stage). The manufacturer advises it needs to be a 20k version and recommends against a shunt type. There is insufficient space and $$$ for a TVC.
Firstly, just how close does a law faked cermet linear pot come to a ladder attenuator like the Goldpoint Mini-L ?
Secondly, are there any pre-assembled ladder attenuators available other than the Goldpoint (I can't find any) ? Do TKD make a ladder or only the series type ?
Many thanks,
Darren.
Hi Frank,
Many thanks,
Darren.
Frank,
This is the URL for the App note by Thorsten Loesch on the TX102's, and much of it would apply to TVCs in general.
http://www.harmonicdiscord.com/forums/viewtopic.php?t=6576
Darren,
<b>Secondly, are there any pre-assembled ladder attenuators available other than the Goldpoint (I can't find any) ? Do TKD make a ladder or only the series type ? </b>
www.dact.com
Cheers
Darren,
www.dact.com
Cheers
Brett,
Thanks for the DACT link, but from what I understand the CT1 & CT2 are "series" type attenuators, not "ladder" types. Even though the DACTs receive favourable comment, I assume that a good series type attenuator will not sound as good as a good ladder attenuator (except perhaps at full volume when there aren't extra resistors in series).
However, if anyone out there has directly compared the two (same impedance rating and used in the same piece of equipment) and had diffferent results, I'm happy to hear about them (and save money).
Darren.
Darren.
You're right about the DACT being a series. Sorry. I can't think of anyone who does a ladder attenuator pre-made. You might be soldering lots of resistors yourself to get one I'm afraid. Let us know if you do find someone who makes them, as I'm sure there are others who'd be interested.DSK said:Brett,
I also agree that a ladder is probably better than a series all else being equal, but build it with quality resistors and switch, or else that improvement may well be mitigated over a series with higher Q R's (only half the number in a series) and the extra switch contact in the path.
Something to consider when you've had it in system for a while, is to change out the resistors in the most commonly used positions with some you really like the flavour of, esp if the initial budget precludes their use everywhere.
The MFR series Philips (actually Beyschlag) MF resistors in the Farnell catalogue are quite nice and only a few cents each.
LADDERS TO CLIMB
As I said,it betters a standard volume pot.Even a decent one and is a lot cheaper.
I think it was a British engineer,Ben Duncan that first mentioned it in the hi-fi press.
I searched a bit already but no luck so far.
A series if good quality cermets were the Sfernice P11 series.
Just can't seem to trace the formula for calculating the resistor network though.
If I happen to find it I'll post it here.
There are quite a few more,and yes,TKD do make 'em too.
But why pay hard earned cash for something that can be assembled in a couple of hours using the components of your own choice?
Just to show how good Google has been to me:
http://www.google.be/search?q=LADDER+ATTENUATORS&ie=UTF-8&oe=UTF-8&hl=nl&meta=
If you want the ultimate VC I would stringly recommend the TVC which is a transformer with various windings controlled by a rotary switch.
Brett mentioned this already previously.
- Design & Build
- Parts
- Ladder attenuator: Where to solder resistors
