LA6458SS replacement?
I am working on an NAD cassette deck I picked up at a thrift store with a bad LA6458SS opamp (9 pin LIP). The only options I have found are Ebay or NTE1529. The NTE appears to be a drop in replacement but I am a bit leery, and ebay is always a gamble.
Should I go with the NTE, ebay, or something else?
I would put a DIL version (4558 or similar dual opamp) on a piece of veroboard and wire it in.
Pin for pin, they are the same.
OR
straighten pins 1 - 4 out and insert them in the pcb running short solid wires to the other pins 5 - 8.
Reactions: bamavette
Got it fixed. The problem was I couldn't get the output level to service manual specs. Suppose to be 505mv with a calibration tape, I was getting 150mv. Changing the chip (trim circuit) brought it up to 250mv. I started checking capacitors in the circuit and a 1000uf was 900uf but had an esr of 150 ohms. Replacing that brought it up the rest of the way.
