Chuck Hollander is a name that comes to mind on that . It's very complicated . I did tell Sid off about it . It is in place of a big choke . The ripple was I guess about 15 V . The 37 V dynamic range of the LM317 copes with that . Problem is it must not swing further . Transient can kill it . I speculated that if the transformer was split somehow it only need see the ripple and not need the protection . LM317 is fast enough for a class A if wondering . It is a bit like making LP's from CD as sometimes happens this idea . Slightly wrong yet it works .
For 100W output from a pair of KT88's the data sheet gives a -75V (Vg1). Should I use this voltage or half of this voltage on the plate I vs E plots? The individual lines shown do not include -75V. Do I need a different plot? -37.5V gives a current up above 200mA this seems really high. If I extrapolate a line at -75V I would get a current of 0±mA at 560Va which seems too low. From what I see B+=560, Eg1=-58.6 to give Ia=50mA???
JW
JW
Here are a some typical operating points for KT88
TDSL Tube data [KT88]
Putting your 560V B+ and a 4.5K output transformer into Broskie's PP calculator software yields a bias voltage of -68V for AB1. The software is for PP triode only, but this would lead me to believe that you'll need close to -75V.
Listening #111 | Stereophile.com
Didn't find what you wanted will ask friends . It says here hum was very good . No idea why he did it . Sid was a musician . It must have sounded better .He used Quad ESL 63 's if wondering .
I wasn't in the slightest bit interested in valves as we call them at the time ( about 1999 I think ) . I met Sid through a friend and had virtually no idea who he was . He talked me into believing capacitors mattered as he had just discovered it himself . I knew before him about it . I said nothing . He had a child s fascination about things . He wasn't high flung you know . He said he always needed other engineers to help .
Eat as much as you can
Technical books online
This is like those buffet meals that say eat as much as you like . Happy reading
I had Art Audio Concerto triode/UL kt88 with variable feedback and cathode bias. One of their early units made in GB-terrible workmanship ,excellent sound I regret I did not copy schematic and manual .It was the best sounding KT88 PP amp I heard to date.I can never get my head around them . I was taught by Sid Smith the designer of Marantz amps . He gave up . He agreed my way works . Very nice man was Sid . Sid used LM317 for HT smoothing . It was arranged to work at 400 V and was a famous modification . I always would use cathode bias as it adjusts the KT88 as it ages . Sid always triode connected his amps at home . Sowter in UK make transformers about as good as SIds .
JW
With todays KT88's, keep Iquies low; or they won't last long at 560V and the business gets costly.
Decades ago, KT88 UL circuits were about that showed Iquies 60mA at 600V+, a non-survivable grilling for todays tubes. That's the reason I went to parallel push pull.
richy
Gu 50 ?
What about the Russian version GU 50 ? It is worth a look . It was what the Germans came up with about 1942 and think was called a Ray Pentode . Time is running out to buy these . Telefunken LS 50 and Chinese FU 50 also .
GU-50 - Wikipedia, the free encyclopedia
http://www.qrz.ru/reference/tubes2/type3/gu50.shtml
This forum is great, my learning has taken leaps since I posted my questions.
I have decided that yes, 560 V is too high and am looking now at 460-480V depending on what I use for a driver tube, if I can use the same B+ for both it reduces the complexity and the part count. It also means I can use the 21st century Maida regulator. Tom has already done the heavy lifting and is selling kits.
So now I need to get my driver up to snuff. At present I have a single 6SN7 drawn as a LTP which will take a 3.5±V up to 124V or about 35 times. It has been suggested to me that I will need more gain when I add the NFB of between 14-20 dB. So now I am considering a pair of 6SN7's wired as a cascode LTP. Can I calculate the gain by finding the gain for a cascode then divide by two for putting it in a LTP?
Ëàìïà ÃÓ-50
Check Wavebourn's posts at these pages; he is the GU50 specialist.
ECC 81 and EF184 are not often thought of to drive KT88 ( 6550 ) . They are possible options . EF184 in Long tail pair perhaps . I don't get involved in PP so out of my depth after that . Look at Quad 11 and see if it can be scaled up . Over to someone who would know on that .
I am looking to buy some KT 88 . I don't want to pay silly money and would use EL156 if I did . JJ is out I think .
http://www.hifitubes.nl/weblog/wp-content/telefunken-el156.pdf
New Quad II forty by TdP which I was checking after it was blowing tubes runs them at 390-400V 100mA in cathode bias circuit . You need Penta Labs Kt88's with ~50W dissipation rate to run in High Power Circuit. Don't forget to confront your design with well regarded circuits. Personally I'd try Allen Wright (may he rest in peace) PP-2 amp.
Penta labs KT 88 . Thanks . The plate dissipation is exactly what I wanted to know .
Modern Penta Lab KT88 Vacuum tube.MOV - YouTube
KT 88 tester
I think this would work OK as a tester ? In a wood or plastic enclosure as it is not isolated . Various valves could be tested and data kept .
For USA I guess a capacitor fed doubler would give the same ?
Put a high grade input signal transformer on it and you would have an amplifier . Safety will be OK then if careful . NE 5534 op amp or boosted OPA 604 would drive it . I have tried something like this in the past built for me by my brother . I felt a mains transformer offered advantages sonically .
The 6V is a switch mode PSU for simplicity ( 6.3 V ) . The -6V bias switch is to lower the KT 88 into a lower bias . That would I guess make an ideal standby switch if an ideal voltage was found ( run from a comparator perhaps with a 1 hour flip flop action ) ? Please improve this idea if you can .
Stontronics 6V 2A Desktop Power Supply Unit T2319ST
Sid Smiths circuit for Marantz 7 C and others
I was asked for this . As far as I know this was originated by Sid . I have heard it and it is good . Remember back then LM317 was very exciting .
DIY Test Equipment for Audio and Ham Radio Enthusiasts
http://community.klipsch.com/forums/storage/3/1592390/Modifying the Marantz 7C.pdf
- Tubes / Valves
- KT88 PP UL Design Help Needed
