KT120 triode operation single stage amp
hi i need consulting to projecta serious curious ampo
input: one for 10 times transformer lundhasl, one kt 120 triode cathoiode bypass poliproylene, output transformer lundhal about 3 k ohm.
Chocke inductive PSU with poly caps 100 microF for channel.
Power transformer: one for 400 VA.
Expedcted 15 w class A2, with damping factoer of about 4.
cabinet : tin search of aggod one for a few bucks , if yopu know one pleas e tell me,
do you think it casn be work?
thanks to all expert for precious suggestion .
by , inertial
wouldn't there be a limit to how hard you can drive a low signal input/step up trafo
or else I guess it would need be a much bigger interstage thing
and the signal needed to drive a KT120 directly would be ...'substantial'... I guess😕
Yes. But depending on his setup it could be usable. For instance. Kees Soeters uses a Lundahl 1:8 stepup in his 300b amplifier.
Burmester or something preamp with low output impedance -> 1:8 transformer -> 27 -> 300b. And that works fine.
The KT120 is easier to drive than a 300b. So it might just work.
It's a Pentode, but OP want to use it as triode , aniway triode = less gain , so I don't know if a x10 x Former (model not mentioned ) woul be enough to drive a Kt120 at full , and yes you need a good preamp to drive a step up transformer , something able to drive a 600 ohm load ...
Whether KT120 or 300B....what you win in terms of gain, you loose in terms of miller capacity.
No matter how you look at it, a KT120 isn't really suitable for a SPUD amp. Use some high-gm video pentodes like 12GN7 instead and you will have more fun.
KT66 ? nice tube, abit like audiophiole version of 6L6
btw, I have seen a new big bottle version of 6L6, looks real nice too
regarding KT66, maybe you can ask George ... at Tubelab Forum, Vendor's...I think he knows when it burns right 😀
