Kt-120 ?
To get anywhere with this tube the g1 needs to be driven by a low impedance source plus able to dump Miller effect, i.e the extra A-g1 varactor capacitive load without running into distortion by doing so. A cathode follower is not a solution as it cannot "pull down".
richy
richy
6C19n(6S19p) is supposed to be a good low impedance driver
I thought it would be a good one to do this
but maybe not good enough
would it be a good idea to have seperate supply to screen grids
connected through chokes, instead of resistor
I had forgot all about this thread...:wchair:
since then, I have bought a completely wrong trafo, ofcourse :smash:
'converted' to parafeed
its far from ideal, but maybe it would still work
but I might use EL509, 6550 ...
By Jove, I think he's got it! 😀 YES!
wow, Kevin, was that you, trying to teach me how to layout a negative bias adjust...🙄
cheers
edit...
well, you know how it is when not doing this stuff for a couple of years, and forgetting how to
and since Im not doing tube stuff 'every day', Im not sure I want to mess with negative bias
thinking of looking at it in 10 years from now, and not having clew about where or what ... 😱
