KSA50 AMP(New production Live in...)
Has stayed for one day in the laboratory,Before sleeping, and everybody shares today's achievement.
1)the 210V high pressure's noise control very outstandingly.
2)Has joined 200 ohm impedance matching in the output.
3)The ARC power circuit and the traditional CRC electric circuit's difference is as follows:
a.The CRC power source, the sound dyed are many,Noise control general,The sound characteristic, like “the monosodium glutamate” were many.
b.The ARC power circuit, the sound dyes are very few, is very straight, dynamic is very strong, that kind of feeling has no way with the writing to express. . .
Please look that the following picture, is the audio frequency output noise,Regarding this test result unusual satisfaction,Then these days started to revise PCB.
Good night!
abin
Hi Abin
Sorry for disturb you from the lab activity
if i look your KSA50 you use 4X BC 6800uf 63uf
so total caps 27.200uf per channel, is this enough ?
if i compare with First (Dupont - Dudek) & second (Pinkmouse) GB KSA 50
they used minimum capacitance is 44.000 uf per channel
diyAudio.com Wiki - projects by fanatics, for fanatics
Hello! PCB has received?
The capacitor use is much large capacity, this decides by you.
You may use 15000UF*4, or is higher.
However I suggested that as far as possible do not use the ring transformer, should better use the EI transformer.
When receives the PCB board, oneself perform the experiment, please remember that the upload picture, lets me also share your achievement.
The Different is in the INPUT STAGE
- Jan Dupont use 2 x MPSA42 - 92, 2 x 2sa970 - 2sc2240 & 2sc3955
- Pink Mouse use 3 x MPSA 42 - 92
- Gxcnabin use 3 x 2sa970 - 2sc2240 & 2SD669
Some people build Jan and pinkmouse version and make comparable
of them, a view diy compare them with commercial version too
