Kriesler stereo 6 model 11-133b Radiogram volume issues L/R channel output issues
Dear ALL
I posses the above mentioned Radiogram, I have already replaced to caps that were cracked on first visual inspection, c23 and c24 they are a hard plastic rectangular ones on outside and paper inside i believe, the volume still goes up and down intermittently randomly and to have any output (still very low) i gotta crank the volume knob up to max...in any sort of input, radio, turntable or aux/ mic inputs, some inputs though only play either left of right channels or one almost inaudible.... so since i'm not electronics expert, just handy with a soldering iron, if anyone has some ideas or what else i should change and what values ( for caps etc) i'd be very grateful, also, how do i test the vacuum tubes for faults with my multi-meter, nothing fancy about it and cannot get a hold of a tube tester.... any help would be highly appreciated. I have also uploaded an image of the electronics diagram.
Thanks in advance.
