Hi guys,
Thanks for the info on the KSA100. I guess I have some decisions to make. I may just try a Mono-block setup as a KSA50.
Heat is the enemy. My cooling fan is already starting to get noisy. I placed it between the heatsink and the case, blowing out. I was afraid that having the heated air passing through it may be hard on it but some folks told me not to worry about it that the fans were designed to run like that. Well, maybe I got a faulty fan but it was nice and quiet when I first installed it. It is beginning to develop a whine. I will have to move things around if I have to place it in front of the heatsink. I don't think it would be a good idea to reverse it and have it blowing into the case. I would lose the cooling on the drivers that I now have.
Which way did the fans blow on the originals?
Thanks, Terry
Thanks, Terry
Hi Guys,
I've got a question as I begin to prepare for the new boards
Is there any advantage/disadvantage to using 6 pair of outputs per channel as opposed to the three pair planned with these boards?
I have some large flat heatsinks that I would like to use since I don't have another tunnel. I also have extra output boards. Would the amp run any cooler if I use more outputs per channel?
Thanks, Terry
Thanks, Terry
Assuming both sets are run within the SOAR, From what I have heard, that unless devices are micro-matched, the set with fewer outputs will sound a little more open and soft. The set with twice the outputs will have a little tigher bass but may sound slightly veiled... However it would take a good pair of ears to hear the difference, I am not sure I am as "gold" ear'ed.
The obvious is that the one with 6 will be more forgiving of any abuse and more power capable.
Attention Group Board Purchasers!
The KSA-50 boards have been shipped and will be here Wednesday morning.... I cain't believe it myself but they are actually on the way! My plan is to first send boards out to buyers of just the amp boards. These boards will all go out Saturday morning as this is the only large amount of time I have to spend at the Post Office. The boards from Brian should be here early next week and those that purchased both boards will have theirs sent out later that next week.
I am also in the process of moving in the middle of all this...
was supposed to move last week.... lazy real estate people
! Fortunately its not a very far move..... less than 1000 feet to be exact. I will have a huge listening room there, large enough for a 5.1 setup of Kleinhorns and intend to have several more amp shoot outs there before winter sets in.
There will be EXTRA KSA-50 and Power Supply boards but they will not be available until after I get unpacked and I will announce when they will be made available. Don't write to me now requesting one as I will just delete your mail, no time to keep track of it
! So keep an eye on this thread for that announcement, besides eveyone wants to be part of the largest thread on DIY Audio and dive in and wade through all of the 400 plus pages of posts
that have been made by this wonderful bunch of people. It should be turned into a book
Mark
P.S. guys... please hurry and post those 5 pages... I hinted that it was 400 plus pages long
Mark
Mark A. Gulbrandsen said:P.S. guys... please hurry and post those 5 pages... I hinted that it was 400 plus pages long!!!!
I'll try to contribute 😎
Thats great news Mark, thanks for all your efforts!
Troy - What do you need to finalize the parts order?
I think the conversation last drifted off into alternatives for the out of stock or unobtainable quantity Dale resistors. So for everyone getting in on the parts GB lets get this straightened out.
~Brad
Parts GB
Just pinging again to see whether or not it is too late to get in on the Parts Group Buy.
Ryan
PS. Apologies for the gratuitous re-submission to push us towards 400 pages.
Ryan
still4given said:Would the amp run any cooler if I use more outputs per channel?
The temperature of the amplifier is determined by the heatsink alone.
Without forced cooling the static cooling factor of the heatsink needs to be at least twice as high for the same temperature level.
On top of that there is no reversed linearity between size and thermal resistance of a heatsink : a heatsink twice as big handles less than twice the number of watts for the same temperature.
And then there is economics :
a combination of a number of output devices and a specific type of heatsink results in a number of dissipation watts per invested dollar. There's an optimum number of output devices for a heatsink that has the lowest price tag for each watt of heat the combo is able to handle. Putting more output devices on the sink adds more dollars than the increase of heat capability is worth.
imo, for a 6 pair output stage, select the output devices on Vbe and Hfe and use base resistors, Terry.
Hi Still4given,
Nice price with a day & a bit to go.
Make sure another DiyAudioer is not bidding against you.
still4given said:
Very nice, but I think it is more fun "rolling your own"...
As for the GB on parts, we still do not have sources for all of them and I do NOT have time to research them now. I listed the parts that were MIA from Mouser, if we find a new source that has all, or one additional source that has what Mouser can't supply...
Anyone can find the parts, and get a price for 50 kits. Then we can add the 3% paypal, the shipping, and a few cents per order for envelopes and waa la the kit price. I will then collect the money, order the parts, kit out the parts and mail.
Hi Andrew,
No, no, no, I'm not bidding on that. I just thought those who follow this thread would enjoy seeing it. I agree with Troy. It's more fun to roll your own. Cheaper too.
Hi jacco,
Here's where I'm at. I have gobs of transistors. At least 20 each of MJL4281/4203 as well as 20 each MJL3281/1302 and even 20 each of MJL21193/21194, so cost per device is not a worry for me right now. I am more concerned about the heatsinks I would like to use. They measure 8" x 12" x 1 3/4" with 5/16" thick back plate and 18 fins. Do I understand that while more devices lower the current per device that there’s still the same amount of heat to be dissipated? I wanted to not use a fan if possible after the hassle I’m having with the one I just used. It is making so much noise. I could mount them face to face and put some fans on them but I would rather not. It would make a huge tunnel that would make the case larger than I would like.
Also, my meter measures Hfe but how do you measure for Vbe?
By the way, I am really enjoying the way this Krell sounds now that I've got the right caps in there. Just lovely. Now if I can just find a quiet fan that can live in there.
Now one answered my question about the fan in the original Krell. Did it draw air in from the bottom and exhaust into the case or did it exhaust out the bottom?
Thanks, Terry
Hi jacco,
Thanks, Terry
still4given said:Now one answered my question about the fan in the original Krell. Did it draw air in from the bottom and exhaust into the case or did it exhaust out the bottom?
Thanks, Terry
I'm pretty sure the fan would not blow down. It was most likely designed so that convection will still occur should the fan fail.
The KSA-100 Mk.II I had (same as the ksa-50 but twice of everything) sucked air from the bottom and pushed it up into the case via the heatsink. The case was ventilated well enough that you could feel a quiet draft 4 feet above the case. The fan was rather quiet.
still4given said:Do I understand that while more devices lower the current per device that there’s still the same amount of heat to be dissipated?
1st question : correct.
2nd question:
the fans on the Krell sucked air through the duct and blew it out on the top.
A: i know
B: you can see it on the pictures of the Krell, the Papst on the Krell blows in the direction of the label
2 reasons:
fans are better at that than blowing air through a heatsink because of pressure differences.
hot air goes up by itself, pushing it down means lower efficiency.
As we talk of a record success of this thread started by Bra, he is cooking up another storm and collecting worthy volunteers already: Nakamichi PA-7 anyone?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=63805
A: i know
2 reasons:
The pictures of the Krells I've seen seem to show the fan at the bottom of of the tunnel. Are you saying that the fan is drawing the air down through the tunnel or blowing it up through the tunnel? Your wording is confusing to me.
No mas, no mas...
I will stop with 3... The Maurio LM3886, Pass Mini-A and this KSA-50 clone....
Partskit GB
Welbornelabs sell all the missing resistors exept the 25ohm 2W, well, not the 100ohm 3/4W but the 1W version should do as nice, shouldn't it?
I don't know what quantity is needed so i didn't send them a e-mail...
Yep, it's blowing air up through the tunnel.
I used two 49R9/1w Dale's in parallel.
Cheers
- Krell KSA 50 PCB
