Not yet he hasn't...
...been travelling, and planning a couple of wedding receptions. What can I say, I am really bad at doing more than a couple of things at a time...
Patience
Stuart
Patience
Stuart
Re: Not yet he hasn't...
Well get ready, i've got another box-o-stuff heading your way.
Stuart Easson said:...been travelling, and planning a couple of wedding receptions. What can I say, I am really bad at doing more than a couple of things at a time...
Patience
Stuart
Re: me to
Hmm, now should I completely abuse my mod powers and make his post disappear....
Re: Re: me to
Man, don't do that, I've got to hit 5000 too! And I've actually read every post. And built a krell clone!
It appears that I'm the only one childish enough and easily amused by trying to hit those numbers.
This has gotta be the biggest thread here by # postings and #views right?
pinkmouse said:
Don't get cocky! 😉
Hi Guys,
OK, as far as the fan goes, I used a Globe Motors A47-B15A-15T1-100 . It worked just fine when I put it in. As a matter of fact it still keeps things cool enough but it is making too much noise. My tunnel is mounted sideways sit hte fan mounted between the tunnel and the back plate of the amp and blows out the back. The air inters the case through holes in the side that cause cool air to flow over the drivers. The whole thing works great except for the noise. Maybe I should have bought a better fan. This one says it's good up to 158 degrees F. Maybe I have exceeded that. It didn't make noise until I let it live out in the garage for a few days. Perhaps it got too hot out there.
OK, now for the P101 vs. Krell. I have been trying to compare them but the P101 is so much louder that it makes it difficult. I tried using two different preamps to get the volume closer but the preamps put their own little spin on things so it is still difficult. After listening to the Krell for a couple of days now I have to say that it has a charm to it's sound that I don't think the P101 can match. It is just a joy to listen to anything on. I can't wait to get that fan noise fixed. It ruins the ambiance during quieter passages. I need a recommendation for a quiet 120v fan that can live with the hot air moving through it.
Troy,
I was kind of kidding you about matching the transistors, but if you are really willing to do it, that would be awesome.
Blessings, Terry
Troy,
Blessings, Terry
still4given said:Troy,
Blessings, Terry
My 2 cents. Remove the fan, bolt the heat sinks directly to the chassis and put the fan on the inside end of the tube. Sound should decrease significantly. The fan would not be as efficient, but it is a closed tube(no leaks so constant pressure through the tube) and I think the added mass of the chassis would help the heat dissipation and in turn offset any losses in fan efficiency.
Matching for 250 should not be a problem, but I still haven't seen anyone jump up and determine a kit price...
ALL-
Again I am looking for participation in this GB... This is not a retail store where you pop in pay money and get parts... This is DIY.
We have not priced all the parts and divided for 50 kits/channels.
Isn't it just to put the needed number of each component in the shoppingbasket of the retailer in question, punch in the adress it's supposed to be delivered to? You usually get the total price before accually placing the order. Then dividing that number by 50.
When all three totals are collected, add the paypal fee and a couple of bucks for the final shipping.
Now, I could be wrong since i generally don't use supliers in america... But someone overthere could probably do it in, say 30min?
still4given said:Hi Guys,
Blessings, Terry
Everyone here will tell you to use a Papst pretty much the world leader having the quietest fans. See this link. Some of the fans (I think they are called variofans) might need another part (temp sensor or something). Note that you can get a used one cheap at this link. I got me one but as its the type that might need another part I've not tried to use it, ok.... I'm not sure how to use it.
Exacumally!
On mousers page, when doing a search for some resistors, you get 2 alternatives. One that ends with "/R" and one without. Is there any difference?
Because some of the backordered items are available /R-less.
one more thing, when you posted the partslist some pages back you wrote:
does R105, R126 100 refer to the part directly beneath?
71-CCF02-F-25 100
R105, R126 100
71-RN65D-F-100/R 100
RB1, RB2, RB3 150
71-RN65D-F-100/R 150
RE1, RE2, RE3 150
Re: Re: Re: me to
On your way to post 5000, how about trying to hit 4444 also?
kmj said:On mousers page, when doing a search for some resistors, you get 2 alternatives. One that ends with "/R" and one without. Is there any difference?
I actually went letter for letter. No subs, so what ever was on the BOM is what I selected. If the /R is a suitable sub is a question for the PCB designers such as Jan, Al or Pavel....
R105 and such were resistors that had no specified value. I did not know what to order.
All-
Why is it that only 2 people are participating in the Parts GB? I know I got a request for parts from more than 2 people.... Pull your weight...
I have a word-file with shippingcosts and a price total but i can't upload it.
Can i send it to you by e-mail?
but for all others:
Price excluding shipping is
Mouser: 694$
Digikey: 284.15$
Welbornelabs: 270$
But if we say 10$ to 13 $ from each company in shippingcosts i think the parts can be sent with 3-day shipping.
Welbornelabs:
100pc V4-4.75k - Vishay/Dale V4 1/2 watt metal film 4.75kohms
200pc V4-1.50k - Vishay/Dale 1/2 watt metal film 1.50kohms
450pc V4-100 - Vishay/Dale 1/2 watt metal film 100 ohms
100pc V2-100 - Vishay/Dale 1 watt metal film 100 ohms
200pc V2-49.9 - Vishay/Dale 1 watt metal film 49.9 ohms
20+40+90+40+80= 270$
So approximate 280$ when 7$ minimum shipping is added.
The 200pc of 49,9ohmresistors substituts for the 100pc 25ohm 2W resistors.
Digi-key
1
150 MPSA92RLRAOSCT-ND TRANS PNP SS GP HV 300V TO92 0 0.15990 $23.99
2
150 MPSA42RLRAOSCT-ND TRANS NPN SS GP 500MA 300V TO92 0 0.14500 $21.75
3
100 MJE15033OS-ND TRANS PWR PNP 8A 250V TO220AB 0 1.05000 $105.00
4
100 MJE15032OS-ND TRANS PWR NPN 8A 250V TO220AB 0 1.05000 $105.00
5
100 1N4148FS-ND DIODE SGL JUNC 100V 4.0NS DO-35 0 0.03900 $3.90
6
100 1SMB5935BT3OSCT-ND DIODE ZENER 3W 27V SMB 0 0.24510 $24.51
Subtotal $284.15
The rest from mouser.
but for all others:
Mouser: 694$
Digikey: 284.15$
Welbornelabs: 270$
Welbornelabs:
Digi-key
1
2
3
4
5
6
Subtotal $284.15
Didn't see a 5k trimpot on the list, so I found an in-stock candidate at mouserBourns Trimpot
50 of them would be $120
Add that to the total above, accounting for shipping, paypal and packing materials divide by 50 and it looks like $30US per side. Correct me please if I am wrong.
Al- there is a 22k trimpot on you BOM for R1. Is this on the current board? What's it used for?
~Brad
~Brad
prices refer to these parts.
Parts required for 50 channels. We had a pre-request for 42, and then 4-8 more. I would order 60ish channels for spares/mail losses.
Digi-Key parts
Part # Total
MPSA92RLRAOSCT-ND 150
MPSA42RLRAOSCT-ND 150
MJE15033OS-ND 100
MJE15032OS-ND 150
1N4148FS-ND 100
1SMB5935BT3OSCT-ND 100
Mouser parts
Part # Totals
71-RN65D-F-1.0K 50
71-RN65D-F-22K 150
71-RN65D-F-47.5K 100
71-RN65E-F-4.7K 150
71-RN65D-F-1.5K 200
71-RN65D-F-9.1K 250
71-RN65D-F-100/R 200
71-RN65D-F-3.32K 100
71-RN70C-F-100/R 100
71-RL20S-G-820/R 50
71-CCF02-F-25 100
R105, R126 100
RB1, RB2, RB3 150
RE1, RE2, RE3 150
5982-15-300V680 50
647-UVZ1E102MPD 100
505-FKP10.1/400/5 100
5982-5-300V47 100
5982-5-300V100 100
647-UVZ1H100MDD 100
I had originally figured 42 channels x 25%, but have since been told 25% was to much for spares.
~Brad
Al's BOM is a direct decendant of Jan's, and the part kits should work on both sets of boards. So the 22K may have been a JAN specific part.
Great work both of you. I will try to get a single channel price together tomorrow and start accepting money.
A 7 day order period, 3-4 day supplier shipping, and 4-8 day turn-around to get kits out the door...
Edit:
stgrab@yahoo.com
Audiophilenoob said:Has stuart Easson ever came back with all the parts changes for the 105vdc version of this amplifier?
my post was lost in the bantar 🙁 🙁 🙁
- Krell KSA 50 PCB
