I have a Krell KAV500 with a slight hum when connected to grounded plug but totally silent when connected to a ungrounded one. I know a cheater plug could be used but I want to try and fix problem if possible since I plan on selling and dont want any problems. Anyone run into this issue with this amp? I have changed out the rca cables also and if you use a bad one you get a loud noticable hum in channel a bad one is used in.
Hi, Yes I did run in the same issue in 2 of those amp that I've recapped.
The 2 big philips capacitors were leaking
I have no experience of the amp mentioned, but have encountered this problem many times.I have a Krell KAV500 with a slight hum when connected to grounded plug but totally silent when connected to a ungrounded one. I know a cheater plug could be used but I want to try and fix problem if possible since I plan on selling and dont want any problems. Anyone run into this issue with this amp? I have changed out the rca cables also and if you use a bad one you get a loud noticable hum in channel a bad one is used in.
Are any of the auxilliary units (Tuner, Turntable, CD etc) grounded (we say "earthed" in UK) if so, a Ground loop will be causing this phenomenon.
I like to ground the Amp and ground everything else to the ground terminal at the back of it.
