I'm about to take delivery of a pair of these, both used, they are definitely older units, dating back about 15 years most likely.
One is said to work perfectly, the other has "static" in both channels, and I'm getting it primarily for parts back up to keep the other one in service longer, or, possibly for repair and use.
There are only 4 boards inside. One for display, one appears to be off to the side to drive the transport, one is obviously the power supply, and one handles (presumably) the D/A conversion, and pre-amp section to drive the outputs, balanced XLR and RCA. (Discounting the optional HDMI board, only one of these has it)
Is it possible to generalize whether the fault is most likely in the PS vs the board for driving the outputs? I'm suspecting that on the A/D board/Preamp board that some caps are past their prime, swollen or leaking etc...
Is there much danger in swapping in the known good preamp board into the static one to test if the problem is on that board? Start with PS board swap instead?
I don't have a scope to watch the signals unfortunately, and I know that limits my ability to find the problem, but on many other projects, replacing caps has worked well, and usually visible changes are apparent. I'm just surprised Krell would not have put "overkill" caps in place where needed.
Thoughts?
Thoughts?
