koren's spice models
Hi all,
for those of you interested in spice simulation of tube amp.
I am slowly building a library of triode models.
Actually, I use Koren's model since I found it to better adhere to
real plate curve data.
At the moment only a few tube are present in the library but I hope to develope a good and useful thing.
http://www.geocities.com/koren_model/
I wait for comments and suggestions.
thanks in advance
Federico Scarpa
Hi all,
thanks in advance
Federico Scarpa
Thanks a bunch. I've never been able to get the Koren models to work in micro cap. I just cut and pasted the ecc99 into my lib file, and it worked first time. Thanks again.😎
this is a very good idea!
You will find a lot of new useful model files if you search the forum.
ltspice doesn't like the EL34 model. I get the following message:
WARNING: Can't resolve .param v_6=kp*((1/mu)+((v(g,k)-vg0)/sqrt(v(a,k)**2+kvb**2)))
hi ray_moth
maybe the .param statement is typical of MicroCap
clear that line and put the following
E6 6 0 VALUE={KP*( (1/MU)+((V(G,K)-vg0)/sqrt(V(A,K)**2+KVB**2)) )}
and in the next change V_6 with V(6) as follows
E8 8 0 VALUE={(V(A,K))/KP*LN(1+EXP(V(6)))}
let me know
Federico
let me know
Federico
actual models
http://www.geocities.com/koren_model/triode_models/2a3.doc
http://www.geocities.com/koren_model/triode_models/300b.doc
http://www.geocities.com/koren_model/triode_models/5687.doc
http://www.geocities.com/koren_model/triode_models/6c33c.doc
http://www.geocities.com/koren_model/triode_models/6sn7.doc
http://www.geocities.com/koren_model/triode_models/EL34.doc
http://www.geocities.com/koren_model/triode_models/ecc99.doc
http://www.geocities.com/koren_model/triode_models/vv30b.doc
waiting for your *.gif files
Federico
Federico
EL34 model is strange
The EL34 triode model in class AB1, e.g. with quiescent current of 40mA, doesn't cutoff at 0 mA but at about 20mA. Any idea why that is? I think this is wrong and I've stopped using it.
I've gone back to using a 6CA7 model I got from Duncanamps. With g2 strapped to plate, this cuts off cleanly at 0mA, as I would expect.
hi ray_moth
I am interested in such kind of error.
If you give me the info to replicate it i'll be very grateful.
have you tried to plot the anode curves? are they wrong or different with respect to those reported at Yahoo - 404 Not Found ?
I suspect it is a problem of spice portability: the model works fine in MicroCap.
let me know
thank you
Federico
let me know
thank you
Federico
Hello Frederico,
I haven't tried to plot the plate curves for the EL34 model. I still have the model on my disk but, as I said before, I don't use it any more. The conditions under which I tried it were in AB1 push-pull, with plate-to-plate load of 7k, 400v B+, 220k grid resistor, 1k grid stopper and fixed negative grid bias to get a quiescent current in each tube of 40mA. It was driven by a 6SN7 differential stage with 3mA plate current, 47k plate loads and 0.1uF coupling capacitors.
I am using LTSpice, which can be temperamental at times. For instance, it "sulks" if the input signal amplitude is accidentally set too large so as to constitute an overload. It stalls, complaining that the timestep is too small (so what am I supposed to do about that?); or it says there are floating nodes when there aren't any. This might be due to the failure of negative feedback at clipping, I don't know. Since it refuses to simulate, I can't really tell what it's trying to do or why it can't do it. The error log is mostly gibberish except, perhaps, to the programmers who wrote it.
Another problem is that some simulations seem to take forever, whereas others of apparfently similar complexity can be very quick. I have never found a logical explanation for this variability in run-times. The "help" file is not very helpful at all and I would never credit LTSpice with being user-friendly! Still, I got it free, so who am I to complain? When it works, which is most of the time, it seems to be excellent.
Hi ray_moth
i downloaded LTspice and after some time I was able to run the example file with el34 PP without any problems. I found microcap to be much user friendy, however. why don't you give it a try? Yahoo - 404 Not Found
6C4C (6S4S) Yahoo - 404 Not Found
Federico
Federico
I have used both micro-cap and LTspice. I like both, however I will say that LT spice will run circuits with unlimited numbers of nodes and mcap limits you to 50 nodes maximum which can be a problem.
Mcap is much friendlier, but LTspice is far more powerful. (I have successfully run circuits with 400 - 500 nodes and had very good correlation to real world circuits they were modeling.) Configuring spice imperatives to iterate until it converges can be a nuisance, but I have also had to do this in mcap as well.
LTspice doesn't have usable transformer models, but does support K the spice coupling coefficient, and I have had some limited success in getting Norman Koren's transformer models to run in LTspice.
I am going to try some of these tube models in LTspice with the required format changes when I have a moment. I have a large tube library, however I am missing some of the devices you have presented..😀
Great work!
Kevin
Great work!
Kevin
71a Yahoo - 404 Not Found
thank you for your comments Kevin
Federico
ECC88 (PCC88) Yahoo - 404 Not Found
Federico
6С45П (6S45Pi) && 6Н30 (6N30) ...
Ciao!
about desiderata...
what about the Russian types 6С45П (6S45Pi) and 6Н30 (6N30) ??
Ciao!
about desiderata...
hi Pedroskova, Paolo
Please, go to the following site
and read points (1) and (2) for model request. always remember to include the source (link)
845 RCA Yahoo - 404 Not Found
6cm7 double triode with different sections Yahoo - 404 Not Found
two pages
Hi
6CS7 another double triode with different sections
two pages
Federico
two pages
Hi
two pages
Federico
fwiw, I have been trying to get this triode model to work in MultiSim -- it's Koren's with the changes needed by EWB's version and Perugini's parameters :
.subckt 6DJ8 1 2 3
+Params: MU=35 KP=320 KVB=300 EX=1.3 KG1=330
E1 7 0 Value = {(V(1,3)/KP)*LN((1+ EXP((KP/MU) + ((KP*V(2,3))/(SQRT(KVB+V(1,3)*V(1,3)))))))}
RE1 7 0 1e12
G1 1 3 VALUE = {{(((V(7))^EX)/KG1)*(1+SGN(V7))}
RCP 1 3 1e12
C1 2 3 2.3e-12
C2 1 2 2.1e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.model dx d(is=1e-09 rs=1 cjo=10e-12 ttn=1e-9)
.ends
it isn't really happy, although it doesn't blow up...
.subckt 6DJ8 1 2 3
RE1 7 0 1e12
RCP 1 3 1e12
C1 2 3 2.3e-12
C2 1 2 2.1e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.ends
there are some typing mistakes (G1)
try these lines instead
E1 7 0 Value = {(V(1,3)/KP)*LN((1+ EXP((KP/MU) + ((KP*(V(2,3)+.5))/(SQRT(KVB+V(1,3)*V(1,3)))))))}
G1 1 3 VALUE = {(((V(7))^EX)/KG1)*(1+SGN(V(7)))}
.model dx d(is=1e-09 rs=1 cjo=10e-12)
and put EX=1.5
you'll end with a working model
and put EX=1.5
two new models
6189
6c19c
http://www.geocities.com/koren_model/triode_models/6189.doc
http://www.geocities.com/koren_model/triode_models/6c19c.doc
bye
Federico
6189
6c19c
bye
Federico
- Tubes / Valves
- Koren's spice models
