I'm looking for high quality aluminum knobs. Yes I see the ones on the store. Who thinks the garish chrome knobs would look any good with a black or silver faceplate. So only one choice Black. Would like to find some along the style of
Counterpoint with that sculpted look or something like the Audio Research. Any one know? DIY Audio store should offer much bigger selection.
I'm with you there! It hard to find nice knobbies for projects, even the thousands at digikey seem kind of cruddy. I eventually found some like the old counterpoint/ Levinson but I forget where.
Knobs | Hardware, Fasteners, Accessories | DigiKey
These 2 at partsconnexion may be similar to old Counterpoint gear.
ConneX Knobs 28mm Clear Matte Aluminum (for 6mm Shaft)
ConneX Knobs 28mm Champagne Matte Aluminum (for 6mm Shaft)
There was another thread on this I think....
Is this what you mean by "contoured"? Other sources sometimes refer to these as "duckbill".
Anodized Aluminum Rotary Encoder Control Knob OD: 22mm / H: 21mm
If you can find a picture of something you like post it here to help narrow down a search.
Silver, black, two different sizes, take your pick.
And reasonable.
Knob - Aluminum, Set Screw, Notched Tip, 1.25" Diameter | Antique Electronic Supply
Knob - Aluminum, Notched Tip Indicator, Set Screw, .75" Diameter | Antique Electronic Supply
And reasonable.
- Design & Build
- Parts
- Knobs Damn it!!
