Klipsch KG3.5 with Tube Amp??
Does anybody got any experience/opinions about using this speaker with a 25W tube amp or an Aleph30?
I saw them at a friend's friend's house, which is going to emigrate soon. He is going to sell them and I might get 1st option on them if they are worth buying. I would use them as main speakers on a stereo system together with either a 25W tube amp or an Aleph30. Unfortunately the current owner is not in the country now, so I cannot borrow them to listen too with my system.
Here are their specs and a pic.
FREQUENCY RESPONSE: 36Hz-20kHz±3dB
SENSITIVITY: 94dB @ 1watt/1meter
POWER HANDLING: 65 watts maximum continuous (325 watts peak)
NOMINAL IMPEDANCE: 8 ohms
ENCLOSURE TYPE: Bass reflex via front-mounted port
DRIVE COMPONENTS: Two-way system using one 1" (2.54cm) polymer dome compression driver tweeter with a 90°x40° Exponential horn and one 8" (20.32cm) ICG cone woofer
TWEETER: K-84-K 1" (2.54cm) Polymer dome compression driver
HIGH FREQUENCY HORN: 90°x40° Exponential Horn
HIGH FREQUENCY CROSSOVER: 1800Hz
WOOFER: K-1002-K 8" (20.32cm) Injected Carbon Graphite cone
DIMENSIONS (H x W x D): 33.5" (85.1cm) x 10.5" (26.7cm) x 11.5" (29.2cm)
WEIGHT: 39 lbs. (17.7kg)
ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
FINISHES: Whitewash, Lt. Oak, Med. Oak, Cherry, Walnut, Black Satin veneers, Black vinyl
YEARS BUILT: 1994 - 1997
Thanx for all advice/comments.
im not using the subs with a tube amp. so theres no problem with jumping around. just gets them out of the way.🙂
im using a bogen db20 push pull from 1950 its only 20 watts
so im sure whatever you setup with those speakers is going to sound sweet:devily:
i could order a set of that model for the floor at work.but im living in a apartment so small is good:clown:
im going by the make not the model:mafioso:
mine are rated at 75watts peak 300watts model sb1
